Author Topic: Ideas for an inexpensive backdrop?  (Read 14043 times)
Matt Collins
« on: July 26, 2012, 10:13:45 am »
Doing a stage in an arena, seeking ideas / examples of visually exciting backdrops that are fairly simple to implement and inexpensive.
Thoughts?
TJ (Tom) Cornish
  • St. Paul, MN
Re: Ideas for an inexpensive backdrop?
« Reply #1 on: July 26, 2012, 11:33:29 am »
Thoughts?
If you don't need rear lighting capability, muslin backdrops are relatively inexpensive, and can be lit well with usual lighting.  Rosebrand and others make these with or without fire ratings.  Here's a show that I LD'd with a 36' X 18' muslin backdrop.  Light is 16 Chauvet SlimPar Pro RGBAs, some Lekos, and 2 Varilite VL770 movers.
The top of the backdrop was angled due to the roof line of the room we were in.
« Last Edit: July 26, 2012, 11:36:26 am by TJ (Tom) Cornish »
Joshua R Berneking
« Reply #2 on: July 26, 2012, 12:56:35 pm »
This is black shade cloth just like you would purchase at any garden store, just crumple it up creat some bunch points with zip ties etc and light with colored lights.
Or these are just strips of bright aluminum screening crumpled up and hung with some lights on them.
Thoughts?
James Feenstra
« Reply #3 on: July 26, 2012, 12:58:25 pm »
non-black backdrops suck if you want any kind of light show
the darker the backdrop the better!
what kind of show are you doing? that will influence decisions heavily
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #4 on: July 26, 2012, 01:17:38 pm »
That depends on how much light you have to hit with and what you're trying to achieve.
James Feenstra
« Reply #5 on: July 26, 2012, 01:24:53 pm »
hence 'light show' not 'lighting the stage'
the more lighting you have (or want to see), the darker the backdrop should be
www.elevationav.com
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #6 on: July 26, 2012, 01:41:42 pm »
If by "light show" you mean beam effects, then I agree.  I'm not sure that's the only definition of light show.
Matt Collins
« Reply #7 on: July 26, 2012, 03:27:07 pm »
It's a conference with talking heads and will be in a 360 arena with stage at one end; not ideal conditions by a long shot.
James Feenstra
« Reply #8 on: July 26, 2012, 11:29:01 pm »
I don't see how one would define light show any other way, as that's typically what people think of first
i suppose you could have a theatrical light show
keep in mind i do mostly rock and roll
as the op's show is a corporate show, black will still be appropriate, plus the video guys will like that a lot more than any other color
www.elevationav.com
  • Old enough to know better
  • Audio Plumber
« Reply #9 on: July 26, 2012, 11:34:57 pm »
Black is a terrible BG for video. You would be much better off with a medium gray that can be lit for different looks. This is a great use for movers since they make it easy to change color and patterns. LED wash units that can change color are good too.
Black is a leftover from old theatrical drapes, and on a corporate just makes it look like you don't care, or can't afford to make it look better.
Page created in 0.055 seconds with 23 queries.
