Author Topic: even fog distribution.  (Read 1723 times)
Ted Christensen
« on: June 12, 2012, 07:12:28 pm »
Got a an antari 1600 watt fogger this week. It's a newer one with digital display and 3 pin or 5 pin dmx. Whats important about this fogger is how great it is.
I took it one step further do get a even fog across stage using pvc pipe. Used a t bar in the center for the fogger and then on both sides ran a 5ft pvc tube attached to that. Spaced wholes acordingly using ten holes on top and capped the sides and put two more holes there. Very even distribution except the inside of the pvc gets messy.
Was wondering what other people are doing?
Danley SH46 / Th115 / EV ZX5 / EV QRX212H / QSC HPR / Lab Gruppen / Chauvet / Blizzard / Allen and heath ilive
duane massey
Re: even fog distribution.
« Reply #1 on: June 12, 2012, 07:56:59 pm »
No matter what you use you will get moisture in the tube(s). We used to build all sorts of contraptions with blowers, duct work, moisture traps, etc, but the best method is to keep the duct as short as possible (and clean it regularly).
Duane Massey
Houston, Texas
James Feenstra
« Reply #2 on: June 14, 2012, 12:08:30 am »
8" diameter poly tubing + 8" fan + pencil (for making holes)
costs about $0.08/ft (you have to buy it by the roll though....~2500'), just throw it out after a gig
perfect haze outdoors
inside, there's zero point in it as you can just fill the room
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Rick Earl
« Reply #3 on: June 20, 2012, 03:33:57 pm »
In a pinch you can buy diaper genie bag which is basically the same endless bag tubing but available at most discount stores.   A little more expensive, but saved my butt a time or two.
Page created in 0.053 seconds with 24 queries.
