Pages: 1 2 [3] 4   Go Down
Author Topic: What is the purpose of this bolt on my EAW LA400?  (Read 12834 times)
Jeff Bankston
Re: What is the purpose of this bolt on my EAW LA400?
« Reply #20 on: June 07, 2012, 01:54:59 am »
So it's a belly button.
LMAO ! good one dude , good one !
drew gandy
  • Chicago and burbs
« Reply #21 on: June 07, 2012, 10:18:54 am »
It had a purpose in the factory but now it's just sexy.
Arrogance is usually far worse than ignorance. But every once in awhile they swap places.
Douglas R. Allen
« Reply #22 on: June 07, 2012, 04:41:49 pm »
it is internal bracing.
I'm sure you knew I was joking around. Right? ???
Douglas R. Allen
paul bell
« Reply #23 on: June 07, 2012, 10:17:43 pm »
If a cabinet needs to be hung on a wire for spraying a finish, they'd use a driver mounting bolt/T-nut hole. They wouldn't waste time & hardware drilling a hole and installing a nut & bolt.
Tom Young
  • Global Moderator
« Reply #24 on: June 08, 2012, 02:38:31 pm »
How would they cosmetically dress the hole once the paint dries ?
Tom Young
Oxford CT
203-888-6217
paul bell
« Reply #25 on: June 09, 2012, 12:35:47 am »
Using a hole under the grill eliminates the cosmetic needs of the finish covered by the hang wire.
Jeff Bankston
« Reply #26 on: June 09, 2012, 05:59:57 am »
its the master bolt that holds the entire cabnet assembly together.
Tom Young
  • Global Moderator
« Reply #27 on: June 09, 2012, 06:51:12 am »
If you consider where the grille is on the LA400 this might not be as sensible as you think.
The hole, if left open, is an air leak in the compression chamber. It needs to be plugged.
« Last Edit: June 09, 2012, 07:03:36 am by Tom Young »
Tom Young
Oxford CT
203-888-6217
James Cotton
« Reply #28 on: June 09, 2012, 02:21:52 pm »
It's obviously the restraining bolt.
Don't remove it or you may wake up in the morning to find your speaker has wandered off into the desert in search of it's real owner.
Chris Davis
  • USA
« Reply #29 on: June 09, 2012, 11:17:51 pm »
If you remove it, then it is no longer an EAW speaker.
Pages: 1 2 [3] 4   Go Up
Page created in 0.064 seconds with 25 queries.
