Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > DJ Forum
New Outdoor DJ Sound System Reccomendations
<< < (2/2)
Fernando Lopez:
--- Quote from: James Kessell on March 22, 2011, 12:15:33 AM ---Anyone else ?
--- End quote ---
Get 4 ZXA5-60 and 4 ls801pb
Since those tops have 60 degree horizontal dispersion you can place 2 per side and with the 2 inch high the music will project longer. Those subs speak by themselves, they are really loud
Vince Gibbs:
--- End quote ---
I use 1-2 Yorkville Elite LS800P subs for events like this.  These things kill!!!  If you need a loud powered sub that makes the earth move, you owe it to yourself to hear these.
Mere words can not describe.
Brad Weber:
--- Quote from: Fernando Lopez on April 07, 2011, 03:06:06 PM ---Since those tops have 60 degree horizontal dispersion you can place 2 per side and with the 2 inch high the music will project longer.
--- End quote ---
Can you explain how "with the 2 inch high the music will project longer"?
Fernando Lopez:
--- Quote from: Brad Weber on April 22, 2011, 08:06:08 AM ---Can you explain how "with the 2 inch high the music will project longer"?
--- End quote ---
Poorly Written
The EV ZXA5 has a 2 inch voice coil, 1 inch exit horn
It should cover the needs of the op
Stephen Snipes:
personally not a fan of the prx series but then again that is partly because I have the vrx918sp.  I would go with the 4 zxa5 60 degree though of course.  I have the 90 degree version because 75% of my events I only need 2 tops.  With the QSC I would go with 4 K or KW 12" tops and 4 - 6 vrx918sp subs.  I like the yorks but to a certain extent
Navigation
[0] Message Index
[*] Previous page
Go to full version
