Author Topic: How to measure the frequency response of a vocal mic?  (Read 3215 times)
John Penkala
« on: May 01, 2012, 04:42:59 pm »
I am seeking advice on how to measure the frequency response of a vocal mic. In this case the mic is an Audix OM7. I read an old case study where an omni measurement mic (reference) and the vocal mic (measurment ) were used. The mic capsules were placed next to one another on axis to a speaker that had pink noise running through it. Is doing a TF measurement this way proper?
JP
Tom Young
  • Global Moderator
Re: How to measure the frequency response of a vocal mic?
« Reply #1 on: May 01, 2012, 04:50:28 pm »
JP
Yes.  This should provide a very close representation of the frequency response of the compared microphone. The more accurate (flat) your reference microphone is, the better.
Tom Young
Oxford CT
203-888-6217
Paul Tucci
« Reply #2 on: May 01, 2012, 09:04:03 pm »
JP
JP,
A Transfer Function is a difference measurement. The two probes, Reference and Measurement might be before and after a piece of gear that causes time or frequency changes. (ie, delay or EQ) They can also be two probes measuring the same signal as is your case. That's valid. I would physically arrange the mics so that arrival times are synchronous, so that the Reference needs no time offset for a good measurement.
What the Transfer will not take into account is the proximity effect of the mic, if applicable.
Tucc
Uwe Riemer
« Reply #3 on: May 02, 2012, 03:20:51 am »
JP
IMO for high frequencies the result will become unvalid, because the two mics will "see" each other
the measurement mic response will be disturbed more by reflections coming from  the OM7 than the other way round
To avoid this problem good old single channel FFT shines, where you do first reference measurement without the DUT and then put the DUT in exact the same place
oops another problem
Uwe
Page created in 0.049 seconds with 24 queries.
