Author Topic: Passively splitting DMX  (Read 5980 times)
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« on: April 25, 2012, 11:44:05 pm »
What's the rule of thumb about doing this? I'm thinking about putting together some LED 4 bars with power and signal run through the bar. Would it be OK to take a DMX in and split it among four fixtures and a DMX out? What would be the issues if say, I had four of these bars built like this?
Chris Buford
  • Richmond, VA
    • My Website
Re: Passively splitting DMX
« Reply #1 on: April 26, 2012, 12:26:04 am »
From what I understand, passive splitting is a big no-no.
What you need to do is daisy chain the DMX through each of the fixtures. You can still have and in and an out at the end of the bar.
Don't think of DMX signal like power runs. Think of it as one straight signal from your controller through every fixture to your last fixture (provided you're not using real DMX splitters)
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #2 on: April 26, 2012, 07:46:02 am »
Passive splitting is a no-no. Your two choices are either routing your cables so you daisy-chain, which seems like could still probably be done with cables inside the bar, or an active DMX splitter, which aren't expensive, and come in form factors that can be clamped to truss.
Tim Weaver
« Reply #3 on: April 30, 2012, 01:12:51 am »
My thought was to use an opto splitter for branches, but having the 4 bars internally wired with passive splits. It's a total no-no? Even with proper  termination?
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #4 on: April 30, 2012, 08:56:49 am »
Why can't you just do this - pull the cable from the last fixture back through your pipe to your "out"?  What am I missing?
James Feenstra
« Reply #5 on: May 02, 2012, 02:10:48 am »
it's less cable (although more connectors) to wire it in series like it should be
wiring dmx in parallel increases dmx reflections a lot, and the more passive splits you throw into the mix the worse the problems get. termination will generally not help this problem.
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Page created in 0.04 seconds with 23 queries.
