Hi All,
I recently bought a pair of Hybrid PLB215 speakers (South African). These are basically double tops (two woofers and tweeter per cab). A few days after I bought tested them at home and found that while the one speaker plays or sounds "normal" the other one is almost inaudiable with both speakers playing. I actually had to turn down the other one in order to hear it.
Now since I bought them brand new I really and I haven't played them at excessive levels I am confused as to why the faulty speaker is playing at such a low volume. I even tried using differnt amps and switched cables but it doesn't help. Someone said to me it might be that the passive crossover that got damaged during shipping. Is this plausible? And could the crossover be responsible for the low volume output?
+ 1 If the loudspeaker has a warranty do not open it up as this might void warranty.
It sounds like these are brand new, and very recently ('a few days') purchased. You should bring them back to the dealer you bought them from.
IF that's not an option, ... you're on the right track with the process of elimination.
You tried a different cable, and a different amp, so it's likely the cabinet.
Did this cab ever play right? IF so, How long ? Might help us to help you, to know.
Does the tweeter,
and both 15s play at the same very low volume?
If so, that would indicate trouble in the input jack connections, or the crossover, and as others noted, might be a fuse, or other protection. Do you have a VOM ( volt -ohm meter) ?
Can you check basic continuity ? You can ohm check the fuse(assuming there is one) for continuity, after removing it.
Is the jack 1/4 inch type, or speakon ?
Could be a damaged jack, if the 1/4 inch type. they can get crunched if the cord gets stepped on while plugged in.
Give us as much information as you can,
Thanks,
