so i happen to come across a prety good deal on a 16 cab count on this line array , the specs are the following
Overview /
specifications c-212x
Tri amp configuration (NL8) 2x12", 1x3" diaphragm
Frequency Response (+/-3 dB) 55 Hz - 19 kHz
Program Power (watts) LF-800, LF2-800, HF-200
RMS Power (watts) LF-400, LF2-400, HF-100
SPL & Sensitivity (1w/1m) 136dB / 106dB
Coverage Angle 90 x 10 degrees
Nominal Impedance LF-8ohm, LF2-8ohm, HF-8ohm
Dimensions (HxWxD) 36.22" x 22.44" x 14.56/10.62"
Weight & Material 114.64 lbs 3/4" birch plywood
i havent really heard this system up front , but looks very promising , i use these for rentals for electronic events and social partys , thanks guys:D
