Pages: 1 2 3 [4] 5   Go Down
Author Topic: JTR Triple 12 and Orbit Shifter  (Read 36834 times)
Robert Patch
Re: JTR Triple 12 and Orbit Shifter
« Reply #30 on: January 21, 2011, 01:46:33 pm »
An email from Evan,
"The picture posted was one of 5 mic positions, and that was the one that gave me the least coherence in the HF. The cardboard was removed for the measurements posted on PSW, and I picked the best looking results for the forums."
Sorry if my photo was an incomplete picture.  This is all pretty new to me.
Art Welter
« Reply #31 on: January 21, 2011, 02:13:17 pm »
Jeff Permanian wrote on Thu, 20 January 2011 17:09
Orbit Shifter:
http://i79.photobucket.com/albums/j123/racingxtc7/ObitShifterFR.jpg
2 watt so minus 3db for a 1 watt
Jeff,
“2 watt so minus 3db for a 1 watt “ so -3 dB from the 98.3 Hz 110 dB peak, we get 107 dB.
At 36.6 Hz the graph shows 103.6 dB, keeping in whole numbers 104 dB -3 dB is 101 dB.
Halfway between the two is 104 dB, yet you rate the Orbit shifter sensitivity at 106 dB at 8 ohms in your web site specifications.
index.php/fa/34831/0/
2 dB is not a big deal, but a discrepancy.
If the test used a 4 volt signal, that would be 2 watts at 8 ohm.
However, 4 volts is 8 watts at 2 ohm, if the Orbit Shifter speaker was wired at 2 ohms and driven with four volts, the  adjusted one watt sensitivity would be 98 dB, which would be a large discrepancy.
Would you please explain the 2 dB (or possibly 8 dB) discrepancy, and tell us some measurement details, such as the voltage used, the impedance (2 or 8 ohm), distance from microphone to speaker, microphone calibration, and distance to any walls ?
Art Welter
Steve Hurt
« Reply #32 on: January 21, 2011, 02:39:02 pm »
That's odd.  (The spec page)
I thought my Orbit Shifter were 4 ohm.
Have to check that.
Art Welter
« Reply #33 on: January 21, 2011, 04:24:53 pm »
Steve Hurt wrote on Fri, 21 January 2011 12:39
Have to check that.
Also odd that the Growler is rated at 100 dB sensitivity, yet is within a dB or so of the  JBL SRX718, rated at 95 dB sensitivity.
index.php/fa/34838/0/
Phil’s test results look to be a few dB high overall.
Hopefully, Jeff will clarify.
Steve Hurt
« Reply #34 on: January 21, 2011, 05:04:19 pm »
If the SRX are rated in full space (and JBL sort of says they are) the difference in subs specs, and at the same time, similarity in Phil's measurements, would make a lot of sense.
Art Welter
« Reply #35 on: January 21, 2011, 07:29:56 pm »
Steve Hurt wrote on Fri, 21 January 2011 15:04
The SRX subs are not measured in full space, neither were Phil's measurements of either sub. His measurements of the JBL are within 2 or 3 dB of the JBL chart, considering his microphones are not calibrated or big buck, that is pretty close.
I recently (finally) got to compare my dual LAB 12" front loaded sub to a JBL SRX 728 outdoors, either the 728 sensitivity is what it is claimed, or my subs magically gained 6 dB  Laughing .
Grant Conklin
    • http://www.G-ForceProAudio.com
« Reply #36 on: January 21, 2011, 08:20:17 pm »
Art Welter wrote on Fri, 21 January 2011 18:29
I'd be interested to see the results of that comparison.
Dealer for Fulcrum-Acoustic, JTR, Yorkville, VTC, FBT, Xilica, Hosa, Gator Cases, and On Stage Stands.
« Reply #37 on: January 21, 2011, 10:17:21 pm »
Grant Conklin wrote on Fri, 21 January 2011 20:20
http://srforums.prosoundweb.com/index.php/m/612837/6883/#msg _612837
dB Audio & Video Inc.
Jeff Permanian
    • http://www.JTRspeakers.com
« Reply #38 on: January 24, 2011, 11:02:35 am »
Art Welter wrote on Wed, 19 January 2011 18:00
But now I know the one watt one meter sensitivity of four front loaded dual Lab 12s is only around 98 dB, I want a pair of DSL TH -218, their sensitivity is 10 dB higher !
Art Welter
Art, Since you've take quite an interest in my specs maybe you should take a look at other manufactures. DSL doesn't make a TH-218 but they do make a TBH-218, rated at 112db sensitivity, 2.83 volts, 2 ohms so minus 6db for a 1 watt sensitivity.
Jeff Permanian
« Reply #39 on: January 24, 2011, 11:10:38 am »
Art Welter wrote on Thu, 20 January 2011 14:20
I have attempted to calibrate my Smaart readings, but am not sure if they are absolutly on.
I have not attempted to calibrate them with the RTA 420 microphone I was using in the above test.
I have  written several times that I can’t get my 3 meters to agree at more than one frequency..
Art Welter
Forgive me if I question the absolute level of your measurements and your correlated sensitivities.
Pages: 1 2 3 [4] 5   Go Up
Page created in 0.037 seconds with 18 queries.
