Jamin Lynch wrote on Fri, 31 December 2010 15:26 |
Kristian Johnsen wrote on Fri, 31 December 2010 01:06 |
Jamin Lynch wrote on Fri, 31 December 2010 03:18 | That's why I ALWAYS make a walk around before I drive off. Even when I'm not pulling a trailer. Check the tires, make sure the doors are closed good, make sure nothing is going to shift, check the hitch, check the lights, and so on. Even if somebody messed with it, I will catch any problems BEFORE I leave.
Always gauge the oil, too?
Seriously, though, that's impressive. With my busy schedule and number of short runs in a typical work day I'd be doing little else on some days. I will, for obvious reasons, be checking the tounge release of my trailer more often from now on, so I do think you do have a point, although not very practical for most people out in the real world.
Yes, if I'm about to go on a long trip, I check the oil too.
I find it hard to believe anyone could be so busy that you can't take a few sconds to make a walk around. How much time did it take out of your busy day to rescue your trailer?
There are NO short cuts for safety.
Jamin.
You can blow your safety-contious horn all you want but I think you're pleading a tough case that it's somehow my fault that someone snuck up an pulled the release handle on my trailer when I had an approved trailer lock installed, and the sabotage happened in such a way that the problem was not visible.
Further, once disaster struck 2 kilometers down the road, my installed safety wire did it's job.
Thank you for your insights. I commend you for finding the time to perform your safety routine for every short drive and I will strive to find the time to do the same.
