Author Topic: Digital  (Read 8081 times)
Randy "razz" Mann
Digital
« on: December 21, 2010, 12:48:17 am »
I am a teacher and have been charged with researching a new sound system for our auditorium. It seats about 700.
I've been advised that a Yamaha LS9-32 is a great board to get. My question is, from the stage to the FOH, is digital more preferential than a 32-8 snake? Is digital more reliable? What equipment do I need for the stage end of the cable? Would it be a fiber-optic cable or a cat5?
There is a huge learning curve to this digital stuff, and I can't find much about it. Any links for information would also be greatly appreciated!
Thanks in advance.
Jordan Wolf
    • http://www.facebook.com/howlingwolf487
Re: Digital
« Reply #1 on: December 21, 2010, 12:56:03 am »
I suggest researching audio install companies in your locale.  Most have a gallery of pictures or a list of places that they've serviced.  Find similar venues to yours and see what is required for that type of space and the types of performances in it.
That will be your best use of time.  A number of people on this forum work for install companies; I recommend listing your location so we can perhaps be of more assistance.
Wolf
"A lack of preparation on your part does not constitute an emergency on my part."
- Me
"With that much comb filtering you could probably part your hair just by walking through the room." - Dick Rees
Randy "razz" Mann
Re: Digital
« Reply #2 on: December 21, 2010, 01:00:17 am »
Wyoming  -  The closest guy I've found that is both honest and knowledgeable is in Denver. I hate to keep bugging him with "simple" questions, so I thought I'd try to bug a different group of people.  Rolling Eyes
The bigger issue is that my boss wants to be "cutting edge" but it looks to me more like the "industry standard" is not digital until you get to the mixer. (standard snake) In your opinion, is the industry converting to digital, running a small cable front to back? i.e. Will this be what everyone is doing in 10 years?
It is also supposed to be "user friendly" - if I were to keel over dead, could the next guy come in and run it?
What are some examples of AD equipment to go on the stage end, so I can get some idea of what we're talking about and how it works?
Brad Weber
Re: Digital
« Reply #3 on: December 21, 2010, 08:36:34 am »
Currently it is still by far the most common approach for all stage connectivity to be analog at the stage itself.  What is becoming increasingly common is digital transmission from the stage to FOH.
Can you tell us more about the situation?  For example, it sounds like it is an existing system, would you simply be replacing the existing copper wiring with an equivalent digital transport system or are you also expanding or modifying the actual connectivity at the stage?  If you are making extensive modifications then that may justify any cost associated with converting to digital at the stage, if you are maintaining the same connectivity then a digital snake may represent additional cost with limited benefit.  If you did got to a digital snake from the stage to FOH, do you have the pathways and access to get the stage cabling to stage boxes somewhere near the stage and then the CAT/UTP or fiber cable from there to FOH?  Would the console always be at one location or do you want to be able to easily use it at multiple locations?  Might you at some point add or need to support a separate monitor, recording or broadcast mixer?
Are you really committed to the Yamaha LS9?  One aspect of this is whether a digital console makes sense for you in general.  Will your operators be familiar with it or will there be someone there familiar with it to handle most of the basic console configuration and to guide other users?  Would you still have a large collection of outboard effects and processors that you'd use?  Will the scene presets and recall it provides be a significant benefit?  Another aspect is how it potentially affects a digital snake.  Some digital consoles are basically a direct analog console replacement approach with significant analog inputs and outputs on the console itself while others are configured from the start around a digital snake concept.  The LS9 can be configured to take advantage of a digital snake, however the default configuration is much more a direct analog console replacement with analog inputs and outputs on the console whether you use them or not and configuring it for a digital snake would entail additional costs.
The overall point is that there is no one answer, it all depends on your specific situation in terms of what is existing, the facility, the use, the operators and so on.  It is not unusual for me to go through a conceptual design and pricing exercise for multiple possible approaches and products before deciding which solution is the best fit for that particular project and it doesn't always turn out to be the approach or mixer I initially envisioned.
Brad Weber
muse Audio Video
Re: Digital
« Reply #4 on: December 21, 2010, 08:52:48 am »
Digital snakes can have their advantages-and disadvantages.  It is usually cost.  Which can be more in some cases and less in others-as compared to an analog snake.
In a simple setup like yours (no recording mix-no seperate monitor console-relatively short run etc) there is no way I would recommend a digital snake-unless you do not have a path for a regular snake-like say you only have a 3/4" conduit.
The digital snake would cost way more, and if you should have a problem-with either the console or the snake-there is no way you could substitute another console out in an emergency.
Just because it is "cutting edge" does not mean that it is better.
We install about 70% digital consoles and around 0.01% digital snakes.
In some situations a digital snake makes sense-but in most normal situations (like yours) I feel it is a waste of money and an area that is opening itself up to trouble.
There is no performance advantage to be gained from a digital snake-in your situation.
Technology can be great IF it solves a problem.  But using technology-just for "technology" sake or because somebody thinks it is "cool" is not smart in my opinion.  If it solves a problem that cannot be overcome otherwise, then that is fine.  But to use it "just because" is foolish.
A digital console can offer you lots of advantages (scene recallability being the biggest) along with lots of control over the individual signals.  But that control is a double edged sword.  It allow great flexability for the person who knows what they are doing, but also hass all kinds of possibilitites to screw up for people who don't know what they are doing.
The LS9 is a great board for the price and it is very popular-which means there are more and more people out there who know how to operate it properly.
If you know how to mix, then a digital console is not that big a deal.  You just have to learn the "knobology"-where the knobs are.  But if you don't know how to mix, and know how a regular analog console operates/signal flow etc, then digital consoles can be overwhelming-but then so would an analog console.  Unless you get a simple mixer that only has volume and a couple of tone controls.
dB Audio & Video Inc.
Jamin Lynch
Re: Digital
« Reply #5 on: December 26, 2010, 02:24:38 pm »
Ivan is absolutly correct.
What do you currently have for speakers and amps? A digital console isn't going to make cheap speakers sound any better. You may want to invest your money there first.
I see this all the time, especially at the churches. They want to purchase a high dollar digital console because it's the latest thing and they feel like it will solve all their problems, while at the same time they have old, low quality, poorly deployed speakers and amps.
There are some really good easy to use analog consoles out there that don't cost a lot of money. This will be a good start for anyone who dosen't have much experience.
Matt Tudor
Re: Digital
« Reply #6 on: January 03, 2011, 06:16:48 pm »
About a year and a half ago I put an LS932 in our 800 seat theater. At the same time we installed another snake to the mix position at the back of the house to eliminate laying a big snake down the isle. The hardest decision that I had to make for that project was deciding digital vs copper snake.
Ultimately I went 48x8 copper. Part of my reasoning was because at the time, we were still seeing some riders/shows using analog boards, and a digital snake can't feed an analog board without converting back to analog. Another concern that I had was splitting to monitor world. With the cost of a transformer isolated split, and a copper snake to my analog monitor board already spent anyway, a multicore to FOH was way cheaper than a shorter multicore jumper from the split to the digital snake plus the cost of the digital snake. I also wanted to maintain the flexibility of putting my digital desk in monitor world, and running analog out FOH if I ever wanted to. I also laid in a couple Cat5s and a couple 110 ohm lines for DMX and digital audio should I need them in the future. I was also uncomfortable with the idea of not having a back up in case the digital snake failed. If my digital board lays down, I have my analogs as a backup. If I lose a channel on the copper snake, I can swap to an unused pair. If the digital snake quits....???
If I had to do that project over again with knowing our current use and newer technology, I'd still do a digital board but definitely be looking at spending the extra coin on one of the smaller I-Live systems, which includes a stage box and CAT5 control cable. In the last 10 to 12 months we haven't had an analog board at FOH once so flexibility is less of an issue than I thought it would be. Also as I understand it, if the I-live stage rack loses connection with the surface, the DSP continues to pass audio till the connection is restored, which eliminates my concern of a failure of the snake. Absent something like the I-live or similar systems, I think I would still have put in the copper multicore.
The LS9 is a good entry level board to work with. I didn't find the learning curve to be too steep, but I've been mixing for a while. I can tell a difference between the students on my crew that learned to mix on our old analog boards and those who have started mixing on the digital board right away. My students who are comfortable with an analog board seem to understand the workflow of digital boards better.
My 2 cents
Matt
Page created in 0.064 seconds with 20 queries.
