Author Topic: Help. What kind of light fixture do I need?  (Read 3924 times)
john lutz
« on: December 04, 2010, 12:17:31 pm »
Not well versed in types of fixtures.  Looking for a sharp edged conical focused beam spotlight that can light performers at short distances in small clubs, say around 20 feet give or take a bit. LED if possible.  Something that won't wash out the whole stage trying to get the faces.  Any suggestions?
Ray Cerwinski
Re: Help. What kind of light fixture do I need?
« Reply #1 on: December 04, 2010, 01:07:14 pm »
http://www.etcconnect.com/product.overview.aspx?ID=20080
Not LED however.
And throw distance is only one factor needed to determine the size lens you need. you need to know how wide of an area you are trying to light with one fixture. You can always shutter the top and bottom of the beam to shape it as needed.
Ray Cerwinski
Fennelli Design Group
www.eventfx.com
Duane Massey
    • http://www.ozknozz.com
« Reply #2 on: December 05, 2010, 04:52:46 pm »
Budget? If you need a focused beam (sharp edge) the ADJ X-Color is worth taking a look at, but it uses a color wheel, not RGB mixing.
Most LED pars are fairly narrow, just look at the beam spread. ADJ/Elation has an LED fresnel that has been fairly popular if you just need white or a gel.
Duane Massey
Houston, Texas, USA
john lutz
« Reply #3 on: December 06, 2010, 10:39:46 am »
Thanks Duane, I'll check those out. Not sure of budget yet.  I know what I want the light to look like, just not the lighting terminology to describe it properly.  Years ago I used some Leico ellipsoidals that had the look - but they were for big rooms and needed to be 50 plus feet from stage.  They threw a white sharp edged beam and projected a 4 or 5 foot circle on the artist.  Trying for that - but in the 10 to 20 foot from stage range.  A "mini-Leico" ?  LED is a plus for power draw and heat.  Small size and low weight is good 'cuz these are just small rooms/stages.
James Feenstra
    • http://www.crewspace.com/James
« Reply #4 on: December 06, 2010, 12:18:19 pm »
an etc source 4 w/ 26 degree lens would be fine at 20', but it's not exactly a 'low power' fixture (either 575w or 750w)
it'd produce a 9' diameter circle on stage at that distance, which could be shuttered in as well to be cut exactly to your performers space used
the zoomable s4 fixtures can get a tighter shot, or you *could* use a 19, 14, or 10 degree lens if you need a really tight shot, although at 20' a 10 degree lens will be about a 3.6' diameter, which is REALLY tiny
James Feenstra
Lighting, Audio and Special Effects Design
Matthew Haber
    • http://www.matthewhaber.com
« Reply #5 on: December 06, 2010, 03:35:01 pm »
+1 to what James said. What you are describing is the beam produced by an ellipsoidal luminaire. At the moment Source Fours have the best price/functionality ration (although I am a big fan of the Selecon Pacific) but they are not LED based. I would go for the 14 (4'ish diameter @20') or 19 (6'ish diameter @20') degree S4 and lamp it at 575w. If you are set on LED and cost is not an issue, you could look at something like the Robert Juliat ALEDIN 631SX which would meet your needs for an exceptionally high cost.
Ray Cerwinski
« Reply #6 on: December 06, 2010, 11:28:55 pm »
James Feenstra wrote on Mon, 06 December 2010 12:18
...but it's not exactly a 'low power' fixture...
he could always jump down to a 375w to save power.
alternatively... http://lighting.ballantyne-omaha.com/ProductView.aspx?c=396& amp;pindex=2
Ray Cerwinski
www.eventfx.com
Tony "T" Tissot
    • http://www.4dbsound.com
« Reply #7 on: December 07, 2010, 03:22:52 am »
Do these folks move?
Much as I hate 'em, nothing beats a cheap spotlight with a low-paid operator for theatricality.
MNGS
ProSoundWeb - Home of 50,000 audio professionals - and two or three curmudgeonly SOBs.
john lutz
« Reply #8 on: December 10, 2010, 09:54:20 am »
Tony "T" Tissot wrote on Tue, 07 December 2010 02:22
Do these folks move?.........
Only to the back-line to turn up or grab a sip-o-beer.  Cool
Thanks to all for input - it will get me started.
Page created in 0.035 seconds with 20 queries.
