Walter Wright wrote on Mon, 06 December 2010 00:34 |
yes, power amps are used all the time for bass rigs, and yes a sansamp pedal into said power amp makes for a lovely bass rig (it's what i use).
a good 4x10 bass guitar cab will have well more power-handling, clarity, highs and lows than a similar-sized single 15 or 18 bass guitar cab. think about it: you've got way more speaker cone area, and it's being driven by 4 voice coils, not just one.
people think they need a 4x10 "for the highs" and a single 15 "for the lows", when that 15 actually just produces more fat midrange, while the 4x10 tends to get the highs and the lows. (i like the grindy, old-school midrange for bass, so i use two 1x15 cabs.)
PA-type subs or cabs are usually not ideal for bass guitar, as they tend to have too much stage-wrecking lows or deadly, directional highs.
In addition to what Walter said (with which I concur), the best bass cabs in my current arsenal have mid-range drivers that provide excellent dispersion on stage; if I've learned nothing else in 42 years as a bassist, it's that great midrange dispersion is critical to provide good sound without inordinate volume; LF is already omni-directional. The frequencies between 100Hz and 800Hz are critical to me because they convey power, solidity, impact, and articulation.
I've played through lots of backline rigs that beamed so badly that, although the audience had lots of bass, my band mates couldn't hear me clearly, and I had to turn up my volume higher than necessary to appease the band.
If the bass cabinet is elevated or tilted toward my ears, I can lower my volume; 4x10 cabinets aim their prodigious sound toward my shins where I can't hear it clearly until I'm several feet away. Bass cabinets like the Ampeg 8X10 typically roll-off rather steeply below 100Hz; ported bass cabinets typically extend to around 60Hz before falling off. Ten-, twelve-, and fifteen-inch drivers beam more than a dedicated mid-range driver.
One of the reasons I like playing venues with pro sound reinforcement is because I can carry a much smaller on-stage rig; with bass through FOH, my on-stage rig can be a three-way 1x12 or 2x12.
One of the reasons so many "small-time" bassists have big rigs and their volume is too high is because they're used to playing without bass in the PA; club survival tactics; they've "learned" that battlefield sound levels on stage are necessary to sound good.
