Paul Walters wrote on Tue, 30 November 2010 18:10 |
Ok another guitar/bass amplification question: I assume the "rule of thumb" only applies to PA amp to cab matching. What is the proper way to match this Crown to a bass cab? I've been looking at 4x10s that are 400w RMS, and this Crown does 400w @ 8ohms bridged... Now physics question: if the major part of our bass sound is low-low end (he plays a 5 string), would a 4x10 or single 15 be better? I'd be inclined to say 15" since the low string is around 35-40Hz, but maybe 10"s can go that low... after all, Mackie made a 4x10" PA sub that was technically audible at 40Hz (-10dB I think)
Your amp has 250 wpc at 2 ohms, 200 at 4 ohms, 145 at 8 ohms.
If the cabinet is 8 ohms, mono it for the most power.
Not much power, so if you want any sound down low, you need something reasonably flat to the low B.
If the response is 10 dB down, 200 watts is of power is needed to equal the level of 20 watts.
Using the proper HP filter for whatever cabinet you decide on is important to keep the bass from flapping the speakers, many cabinets unload with less than 100 watts at 45 Hz and lower.
