Author Topic: Elation vs. Source Four  (Read 7576 times)
Jamin Lynch
« on: November 24, 2010, 03:52:02 pm »
I've used the Elation Opti Par before and they look pretty good. Is there that big of a difference between them and the Source Four pars to justify paying about 3 times the price?
Silas Pradetto
Re: Elation vs. Source Four
« Reply #1 on: November 24, 2010, 03:59:36 pm »
No.
And I even have the Elation Opti-Zoom, so I get a bit of beam adjustment to boot  Very Happy
Chad Costanzo
    • http://www.PyxisIndustries.com
« Reply #2 on: November 24, 2010, 04:27:25 pm »
there is some light output difference and the lens do not change as easily.  Unless you get picky designers or clients they work just as well and I can not complain about them.  I have them on par bars and love them and the price
Chad Costanzo
President
Pyxis Industries
888-PYXISAV
Chad@PyxisIndustries.com
http://Http://www.PyxisIndustries.com
Dealer: Elation, ADJ, Audix, Shure, Audio Technica, EV, Midas, KT, Heil,  Global, Avant, Antari, Hosa, & MORE
Rob Timmerman
« Reply #3 on: November 24, 2010, 06:06:16 pm »
Jamin Lynch wrote on Wed, 24 November 2010 15:52
How about design originality?  Would you rather buy a Behringer DI-100 or a BSS AR133?
For actual differences, the Source 4 PAR is rated to 750W, vs. the Elation's 575W rating.  It's also significantly easier to cross-rent the ETC gear if needed.  The ETC unit uses the same lamp as a Source 4, while the Elation unit has a medium bi-pin base, and can share lamps with many of the Altman and Strand ERS units.
I'm also curious where you get the 3x price difference.  A Source 4 PAR can be had for $150, vs $100 for the Elation unit.
Jamin Lynch
« Reply #4 on: November 24, 2010, 08:07:29 pm »
Rob Timmerman wrote on Wed, 24 November 2010 17:06
That's still a 50% difference in cost. Pretty big when your buying a large quantity. Are the 4's worth $50 more? I've seen the Elation Opti Par for as little as $63.
Dan Brown
    • http://www.reachcomm.net
« Reply #5 on: November 24, 2010, 09:00:01 pm »
Silas Pradetto { wrote on Wed, 24 November 2010 14:59
No.
Um, Silas have you compared a Elation Opti-Zoom to a ETC S4 Parnel.
I have and the Opti Zoom put out about half the light of the ETC, both with 575w lamps.
Also the Zoom control on the Elation is terrible, no where near as adjustable as the ETC.
You get what you pay for.
db
E. Lee Dickinson
    • http://www.leedickinson.com
« Reply #6 on: November 26, 2010, 08:25:59 pm »
Another big difference is in the lamp. The HPL 575 has a very noticeably whiter color temperature than the G9.5 based equivalent. Step it up to the HPL 750 and the output difference is huge.
I love Elation gear, generally, but the Optipar is a toy compared to the Source4.
E. Lee Dickinson
Advanced Visual Production Inc.
sound - lighting - video - design
www.avpric.com
Dave Moldover
    • http://www.dancejamproductions.com
« Reply #7 on: November 26, 2010, 08:43:21 pm »
I have 48 opti pars on lamp bars that tour regularly. For the $ savings you could say they are an adequate replacement for etc but not solidly built as the S4. More than one of the lens holder tabs have broken off and lenses dropped out while in transit. The screws holding the sheet metal tab the yoke bolts through fall out after a while. We've had to locktite them all.
FYI:
The metal socket in the opti par can be removed and you can use the HPL 575w lamps (same as etcS4). this makes keeping spare bulb inventory simpler since we use S4 leekos. It takes about 5min per once you know how to do this. - they are not rated for 750w.
Also, I believe the S4par comes with a 4 lens set. The optipars only come with NSP so you have to factor that into cost if you need other lenses.
Dave Moldover
Dance Jam Productions Inc
Dave Moldover
« Reply #8 on: November 26, 2010, 08:44:12 pm »
I should add...
If I were replacing the whole rig today, I would buy the etc instead of elation even at greater cost.
Dave Moldover
Dave Bjornson
« Reply #9 on: December 02, 2010, 06:53:29 pm »
E. Lee Dickinson wrote on Sat, 27 November 2010 01:25
+100
Buy once, cry once.
Page created in 0.045 seconds with 18 queries.
