Pages: 1 2 [3]  All   Go Down
Author Topic: 4x Behringer Dimmers / power question?  (Read 6948 times)
James Feenstra
    • http://www.crewspace.com/James
Re: 4x Behringer Dimmers / power question?
« Reply #20 on: December 06, 2010, 11:58:50 AM »
if there's a data issue with those dimmers changing the socas around won't solve anything
try this;
console -> first problem dimmer -> lights
if the lights have issues swap the dimmer out for another problem dimmer
what it sounds like to me is that the first in your set of 4 is having a data issue and passing it on to the others, as by your explanation, the attached lights are randomly dimming on and off?
that'd indicate a problem somewhere on the control board
switching to manual mode wouldn't over rule this possibility as it's still accessing the control board and if dimmer #1 is the problem dimmer passing information through it (even a passive dmx loop) could result in the corruption being passed on to the next fixture in line
if you add a moving or LED light into the chain after these 4 dimmers, does it respond properly? that'd be a real easy way to see if it was a control issue being passed through the dimmers, and would likely only result in one being shot as opposed to 4
James Feenstra
Lighting, Audio and Special Effects Design
Shane Presley
    • http://www.bssproductions.com
« Reply #21 on: December 07, 2010, 09:57:02 AM »
Ya I never thought about of possiblity of ONE control board spewing bad Dmx down the line... I will try this out.
Thanks
SP
Pages: 1 2 [3]  All   Go Up
Page created in 0.06 seconds with 21 queries.
