http://s485.photobucket.com/albums/rr215/gordonsound/ if you see any thing else in the album you want let me know
Indoor lighted signage like new
1 40x30 new $400 used in GC $125
2 30x24 new $325 used in GC $100 each
Great for custom indoor signage for bar or nightclub or conventions, trade shows etc
http://www.lightboxes.com/Products/EconomyLine24x30.aspx This is excellent POS Signage, would be great for a restaurant- these can use a transparency so you can change the sign whenever you want /
Misc
Peaver crossover 3-way/ stereo 4/5 way mono in good condition, Balanced in and out -$100 Sold!
2 TDM crossover 2 way stereo 3 way mono in working condition, balanced in and out, includes external power supply-$100
Rane AC22 crossover 2 way stereo 3 way mono balanced in/unbalanced out-$125
Biamp 2400 amplifier - a oldy but a goody heavy and heavy duty - 510 Watts per channel continuous @ 4 ohms $200
Crown Power base 1 amplifier $200
mackie 1400 I amplifier $250 Sold
3 white ATA cases - big enough for mains, monitors, complete bass rigs possibly a 4x12- 2 made of identical white material, one more cream inside dimensions on all are 20x35x35 $150 each
Trunk carpeted inside dimensions approx 48w x 28d x 20h almost vgc $150
Radio shack boundary microphone $20
American DJ analog relay pack $40
NSI Microplex/ analog relay pack $100
8 1K par 64 w/ used bulbs $250
LCP 1 channel analog dimmer controller $40
amdj analog strobe controller $10
3 Video patch bays (trompeter) $10 each
Rev7 remote $40
Digitech RP50 multi fx pedal $40
Matched quartet of groove tube el94 ( unused) $40
peaver edb-1 active direct box $30 !
Boss fs-5l foot switch $10
Signal flex SF2481 foot switch $10
Generic momentary foot switch $10
fender footswitch with channel select and chorus $20
Fischer dual cassette deck $5
gemini cd110 cd player $20 single rack mount player
AMDJ dual cd player parts or ? $20 no control cable
auratone Cube Studio monitors ( not powered) $150 pair
Dean markley promag like new $30
Misc Speaker horns and drivers and parts call$$
Also have some line level (600 ohm) press boxes 1x16 or 1x32 made by Bill Lackey for the goodwill games- used one for a gig with the governor last week worked fine. Press boxes are
Transformer isolated with a pad switch for mic level inputs 1/4 and xlr balanced in and out
$100 for the 16 ch vertion
$150 for the 32 ch vertion
Transformers arent anything special but they work.
I have Plans for a improved pad.
No ground lifts but plenty of Room to add them if you like.
Also have 4 Sabine Feed back eliminators 3 1020 Plus and one 1020 $150 each
Just dug up a SRV-2000( can be reprogrammed as a SDE 2000) make offer
15 pair raw snake cable $2 per foot 900 ft available- roll yor own snake or wire up the studio Belden hi quality
New belden rg-11 spool 1000 ft make offer
Coms – this is one complete set of 2 station coms take it all for $350- compatable with clearcom
Used PH 1 Telex head set Single muff $100
Used telex IC-1 Belt pack $100
Used RTS-350 belt pack $100
Generic condenser Headset power supply $40 (best for use with RTS)
Nady head set w. condenser head set QHM-100 x2 $40
Power supply Generic $40 runs up to 5 coms
Disco lights!
2 AMDJ Crystal lights $50 pair
1 american DJ jewell $40
1 american Dj Odome light $40
2 MBT home run lights $50 each or $80 the pair
Take all the disco lights and get a free fogger and 2 egg strobes for $200
Also available 8 egg type AMdj City flash w/ cable strobes $10 each Used once !
DJ kit
Stanton SK6 Mixer Works great!
2 stanton strt8-20 belt drive turntable
set of generic headphones $100!
Also have coffin for Pioneer 500’s
Drum stuff
Camber 14" crash $20
Camber hi-hats $30
1 Wuhan 12" Splash $20- Sold
1 Paiste Alpha 14” Medium Hi-Hats $125
1 Paiste Alpha 14” Crystal Crash $100
1 Sabian AAX 16” Studio crash $125
1 Zildjin A custom 17' Crash $150
1 Zildjin 22” Ping Ride $175
Zildjin new beat hi hats top hat cracked but working $100? bottom would make a nice heavey crash
Axis Drum pedal $125
Turbo Sound impact speakers
$1200 Cash takes it all! 4 12" mains and 2 Subs
4 impact 120 mains for sale. Very smooth sounding main/monitor 12" and 6.5" hf driver very unique - buy all 4 and get a spare hf driver
These are good for both main and monitor ( lay on side, box is angled) use, these are passive rated @ about 300 watts per. These have both locking 1/4 and speakon jacks.
These come from a Sound system rental co, and have been well maintained with all origanal parts. These are around 15 years old but were used for mostly corparate work.
These look good and function good, Colour is "Turbo blue"- These are Passive unpowered boxes, a step above a Mackie C300 ( Passive srm 450) but same kind of functionality exept a 60 degree dispertion for better arayability.
$600 a pair or $1000 for all 4
I have a PDF Schematic of the crossovers and a PDF of the info sheet, If interested i can send these to you.
I also have 2 remaining Impact 180 subwoofers- These no longer have the passive crossovers ( they can be troublesome anyway) so they must be used with a active crossover ( i can give you the parts and scematic to build your own @ NC) Impact 180's I will sell for $500 the pair or $350 w/ purchase of pair of impact 120's
And one is "turbo blue" and the other is Tan ( You could match these up with that special "for plastics" Krylon paint)
Mixers !
Yamaha PM-1800 mixer 40 channels, 6 aux's, 8 bus, Mute groups and 2 matrixes- Everything works faders recently cleaned- Some meter lights out and rip in armrest vynal( cosmetic only)- no case. includes power supply, PS ambilical and 4 little lights
Cosmetically and functionally very good- best Looking PM 1800 i have ever seen- Spent most of its life in a church and last 2 years with sound company- Completely serviced
$2500 OBO
Allen and heath Mixwizard 16 channels, 6 auxes (1st vertion made in UK) On buttons instead of mutes and no on board FX- Includes SKB mixer case- everything works as it should and case is like new- Mixer looks great
$550 OBO includes case Now $500
Mackie 1604 VLZ - Works fas it should, looks used but decent. 16 channels, 4 auxes, 4 buses. Includes SKB case with broken Latches, i will include bungee used to hold SKB case together
$400 OBO includes Case Now $350
