Pages: [1] 2 3  All   Go Down
Author Topic: Tuba 60 vs. ? ?  (Read 21292 times)
Miguel Castro Rios
Tuba 60 vs. ? ?
« on: November 05, 2010, 11:13:28 pm »
Has any one built the tuba 60??
Any measurements.
We are considering building a couple of them.
http://www.billfitzmaurice.com/T60.html
http://billfitzmaurice.info/forum/viewtopic.php?f=12&t=1 1124
We are wondering if it could replace a conventional Front Loaded. Dual 18" Sub woofer. (spl-wise)
Like the EAW sb850 or SB1000.
Art Welter
Re: Tuba 60 vs. ? ?
« Reply #1 on: November 06, 2010, 04:22:11 pm »
Miguel Castro Rios wrote on Fri, 05 November 2010 21:13
Any measurements.
I have not built them, but looking at the design it is easy to see that it is a very long horn and a larger cabinet than the LabSub.
One to one, I would think it would have no problem outperforming the much smaller subs you mentioned (the T-60 is almost double the size), especially when used in multiples.
The 60 inch depth would be a problem in many venues.
Miguel Castro Rios
Re: Tuba 60 vs. ? ?
« Reply #2 on: November 11, 2010, 12:37:47 am »
Thanks for the info.
It would be nice to compare it to other subs, to have opinions from several users to have a better reference for those of us who haven´t built it... Yet
Stipe Ercegovic
Re: Tuba 60 vs. ? ?
« Reply #3 on: November 30, 2010, 02:21:06 pm »
If you look for (relatively) compact DIY cabinet to replace classic bass reflex double 18"er one of my "Cyclops" may be one of possible choice.
Symetryc tapped horn -designed to quality cover ~40Hz to ~130hz range.
On Free Speaker Plans and Speaker Plans forums ..there are few topics about building CB-18 and one about CBe-18 (standard-extended version)
    http://www.freespeakerplans.com/index.php?option=com_jfusion &Itemid=64&jfile=viewtopic.php&f=7&t=1132Link1
    http://forum.speakerplans.com/build-of-2-cb18s-modified-x10- and-duran-tops_topic40867.htmlLink2
    http://forum.speakerplans.com/four-cb18-cyclops-and-four-mod ified-single-smt_topic44449.htmlLink3
    http://forum.speakerplans.com/beware-the-one-eyed-monster_to pic39393.htmlLink4
    http://forum.speakerplans.com/extended-cb18-cyclops_topic450 15.html - CBe-18 Link
CB-18 standard "Cyclops" ; compact size (W=1052mm,H=576mm,D=618mm)
CBe-18 front extended version (for better stacking stability in higher stacks and slight more LF extension.)
Above noted two versions are built/tested and have reported only very good results and positive impressions about sound and performance.
There is also available CBX-18 - full extended version (W=1152mm, H=576mm, D=700mm)..for even a bit more LF extension and slight gain in sensitivity through usable freq. range) - based on same schema as two smaller versions but this version is still not built/tested
Plans are free for DIY - personal use not commercial production (for sale)
Best wishes,
      Stipe
Art Welter
Re: Tuba 60 vs. ? ?
« Reply #4 on: November 30, 2010, 10:08:59 pm »
Stipe,
Nifty design, but it looks to roll off almost an octave above the Tuba 60 if this sim is accurate.
index.php/fa/33988/0/
102 dB sensitivity is good for a small bin though.
Stipe Ercegovic
Re: Tuba 60 vs. ? ?
« Reply #5 on: December 01, 2010, 09:53:53 am »
Art Welter wrote on Tue, 30 November 2010 21:08
Stipe,
Nifty design, but it looks to roll off almost an octave above the Tuba 60 if this sim is accurate...
Yes you are right by looking at simulations seems like this...
CB-18 is designed to be "universal" bass solution (not dedicated SUB-woofer). So it can cover relatively wide freq. range even when used alone with upper cutoff freq. high enough so there is no need for dedicated kick bins.
Also idea was to improve sound quality at upper cutoff (seems that goal is accomplished successfully)
and improve cone movement stability (at extreme power) by symmetrical cone loading.
While trying to achieve this in pretty compact size extra deep LF extension is sacrificed.
By give-up from these two goals it is possible to fit longer horn path within cabinet of same size.. but than my goals are compromised.
General idea based on same lines defined as in this article by Jeff Berryman:
 http://www.prosoundweb.com/article/building_a_big_woofer_enc losure/LINK
..However builders of CB-18 have reported great SPL flat from 40Hz -up .. with a bit of EQing even from 35Hz achievable (if needed Smile ) - of course HPF @ 30Hz have to be used to protect speaker unit from over excursion damage at high power.
CBe-18 , and especially CBX-18 (I hope once it is built  Very Happy  ) will give bit more LF extension (at cost of a bit larger cabinet size)
CB-18 is 374,5 ltr.
CBe-18 = 455 ltr.
CBX-18 = 464,5 ltr.
all dimensioned with "truckpack friendly" on mind
TUBA60 (dual 12 version) =884 ltr. in very weird dimension/size (huge depth dimension)
Also important to notice for honest comparison ..spl plot for dual 12" Tuba60 (on Bill site) is done as 2,83V on 4ohm load which is 2W/1m plot not 1W/1m. According to this even smallest CB-18 is same or more efficient from 40Hz - upwards.
OK, I must admit under 40Hz TUBA60 is still dominant.
Best wishes,
      Stipe
Kevin Unger
Re: Tuba 60 vs. ? ?
« Reply #6 on: December 02, 2010, 10:53:45 pm »
[quote title=Stipe Ercegovic wrote on Wed, 01 December 2010 14:53]
Stipe,
Best wishes,
      Stipe
The horn's resistance usually adds a few ohms to the nominal impedance, hence the upped voltage.
I don't have the T60 plans, but I'm sure this is why the measurement is done that way.
Phil Lewandowski
Re: Tuba 60 vs. ? ?
« Reply #7 on: December 03, 2010, 09:29:34 am »
[quote title=Kevin Unger wrote on Thu, 02 December 2010 22:53]
Stipe,
Best wishes,
      Stipe
I know that Silas has measured the impedance of his LAB subs with the dual LAB12's.
But with the LAB12's having a 6 ohm impedance and with 2, bringing it down to 3 ohms.  I would guess the nominal would be in the 4-6 ohm range.
I believe Bill measures all his cabs at 2.83v to keep it consistent.  So with the dual LAB12 T60 just slide the response down 2-3dB and that would be around your 1W/1M response.
Take Care,
Phil
"It is good to be Alive!"
L and L: Live Sound
landllivesound.com
Kevin Unger
Re: Tuba 60 vs. ? ?
« Reply #8 on: December 03, 2010, 06:36:53 pm »
Phil Lewandowski wrote on Fri, 03 December 2010 14:29
Take Care,
Phil
Every horn of Bill's I've built has had a higher nominal impedance, Even a small 7ft horn (t39) It add to the impedance of the driver due to it having to overcome the air resistance at the horn's throat. (in a very simple explanation)
I'm curious, so I'll pickup the plans.
Hate to quote Bill's plans directly, but I think it won't be a problem. Here's a short from the t39 plans:
"Horn loading adds the impedance of the horn air column to the
driver’s nominal impedance. A single driver cab may safely be considered a
10 ohm load."
Phil Lewandowski
Re: Tuba 60 vs. ? ?
« Reply #9 on: December 03, 2010, 09:56:52 pm »
Kevin Unger wrote on Fri, 03 December 2010 18:36
Take Care,
Phil
10 ohm load."
I would definitely believe you.  I think what has really been needed for the designs is publishing a impedance plot so that the person building can see what is going on.  Since as you know impedance is going to change with frequency.  I remember for a short time there being on impedance plot for one of the subs on the BFM forum but it seemed to disappear.
Anywho, I would be very surprised if the T60 would be actually classified as a "nominal 8 ohm load".
(Actually the Growler's average impedance is closer to 10 ohms as well, like with the T39.  It just so happens that one of the "standards" is to pick the standard 2, 4, 8... as the nominal impedance; whichever it is closest to.  So that is why a impedance plot is so helpful.)
Take Care,
Phil
L and L: Live Sound
landllivesound.com
Pages: [1] 2 3  All   Go Up
Page created in 0.041 seconds with 21 queries.
