Pages: [1] 2 3  All   Go Down
Author Topic: Help my ID these mystery woofers.  (Read 11040 times)
Tim Weaver
    • http://www.weaverimaging.com
« on: October 12, 2010, 01:42:19 pm »
I bought a storage unit full of sound gear. In it was some JRX 115 cabs that had these woofers in them. One looks factory, but the other has a horrible recone job on it that the spider has come loose. I can't figure out what they are in order to know if I want to keep them or not. Maybe someone here can help!?!
First the factory looking cone....
Notice the lack of any identifying marks. Completely flat back on the magnet. Nice cast basket.
http://i23.photobucket.com/albums/b376/HiSPL/Sound%20for%20sale/woofs-1.jpg
Factory looking cone.
http://i23.photobucket.com/albums/b376/HiSPL/Sound%20for%20sale/woofs-3.jpg
Number on the back of the factory looking cone.
http://i23.photobucket.com/albums/b376/HiSPL/Sound%20for%20sale/woofs-5.jpg
OK, here is the front and back of the bad recone job. The cone fits, but whoever installed it botched it pretty bad.
http://i23.photobucket.com/albums/b376/HiSPL/Sound%20for%20sale/woofs-4.jpg
Backside showing number.
http://i23.photobucket.com/albums/b376/HiSPL/Sound%20for%20sale/woofs-2.jpg
Thats it! Thanks for playing, and the winner receives a lifetime supply of good karma!
-=Tim=-
Art Welter
Re: Help my ID these mystery woofers.
« Reply #1 on: October 12, 2010, 02:45:41 pm »
Tim Weaver wrote on Tue, 12 October 2010 11:42
-=Tim=-
Top is an EV 15B, bottom is EV 15L.
There are different series, the old ones were 100 watts RMS, later ones were 200 watts and 3 dB less sensitive..
The 15L (lead) curvilinear cone allows for extended HF, really only useful for guitar or bass applications. The 15B is a good cone, but does not go very low by today's standards.
Tim Weaver
« Reply #2 on: October 12, 2010, 03:54:51 pm »
Looks like we have a winnah! Thanks Art. This community owes you a lot, due to your almost infinite knowledge of the old and arcane ways of sound reinforcement. Cool
Do you or anyone else know if the 15B cones will fit in the 15L frames? This L needs a recone and it would be nice if I could have a pair of B's instead of a mismatch like I've got now.....
Art Welter
« Reply #3 on: October 12, 2010, 04:15:13 pm »
Tim Weaver wrote on Tue, 12 October 2010 13:54
Thanks.
They are identical magnet structures and frames, you can recone as a "B" or an "L".
Tim Weaver
« Reply #4 on: October 12, 2010, 04:37:22 pm »
Awesome! Thanks Art!
« Reply #5 on: October 12, 2010, 05:10:52 pm »
Art Welter wrote on Tue, 12 October 2010 16:15
Thanks.
And you can also put the Pro line cones-for a bit more power handling.  Yes the frame/magnet assembly does not have all the "extras" that add to the power handling-but at least the voice coils will have the baked on treatment that helps to hold them together.
dB Audio & Video Inc.
Mike Smith
    • http://www.eventtechnicalsystems.com/
« Reply #6 on: October 13, 2010, 07:33:36 am »
They are not EV -- or at least if they are, EV changed their basket tooling. The terminals should sit on a sort of "bridge" between two basket spokes, not on that square cast tab. The spoke profile is similar to EV's but not identical. The magnet back plate doesn't have the proper holes for mounting EV's famous finned magnet cover.
The "15B" cone appears to have a progressive surround, which again may be a newer EV style but not one with which I am familiar. The "15L" cone has a double half roll surround, which is also incorrect, but you already knew it was a recone.
PAS used to make some similar looking speakers, but I think most of that series had 3" voice coils instead of EV's 2.5". Regarding the basket design, more recently there is a flood of Asian-sourced knock-offs that use what is basically open tooling.
It would be fun to cut up one of the ones you have and take a closer look inside.
Mike Smith
Event Technical Systems
« Reply #7 on: October 13, 2010, 11:52:23 am »
I do see the 3 holes for the heat sink fins in the photo.
You are correct that the 15B's I have seen don't have a progressive roll.  But that may be an aftermarket kit installed.
The EV's I have around here have the bridge (as you describe) for the terminals-but I seem to remember (I could be wrong) seeing some EV's with the cast tab.  Although why they would change tooling just for that I don't know.
Good examination.  With a quick glance those look just like 15B's and 15L's, but as you point out-they may be a knockoff.
Tim Weaver
« Reply #8 on: October 13, 2010, 01:18:33 pm »
Mike Smith wrote on Wed, 13 October 2010 06:33
Good eye Mike...
Later today I will cut into the bad one and see what size the VC is. Looking on the web, it *could* be a PAS but I'm not sure. I can't find any images of the back of a PAS woofer.
These baskets are cast and of excellent quality. The fit and finish are first rate. Are the chinese knockoffs finished that well?
Art Welter
« Reply #9 on: October 13, 2010, 01:26:59 pm »
Mike Smith wrote on Wed, 13 October 2010 05:33
Damn memory is not as clear as I thought.
After looking at my old EV catalog, I agree these speakers are  different, the spokes on the EV are more "L" shaped, these are a triangle.
The "15B" surround looks the same as the old EV reprint, but the "15L" double half roll surround looks different.
I have not opened a JRX 115, wonder if these are some JBL OEM thing?
Pages: [1] 2 3  All   Go Up
Page created in 0.062 seconds with 18 queries.
