Author Topic: German made KME & KS Audio  (Read 5903 times)
Jamie Rose
« on: October 12, 2010, 11:09:17 am »
Any of you try or hear before the above products ? I heard KME has a very clean Vocal & natrual tone but I can't find any review. KS Audio ; looks good on paper & great installation references. Agian, no review on web as well. Please share your opinion. Thanks
Jamie
Steve Nichols
Re: German made KME & KS Audio
« Reply #1 on: November 12, 2010, 10:18:17 pm »
KS Sounds good. I chose the Seeburg A6 and TSM SUB Dp+. 1000w for low and highs with DSP and X-Over. Very clean and powerful. They use Powersoft modules.
Jamie Rose
« Reply #2 on: November 15, 2010, 01:50:57 am »
Thanks. Are they better than ks or kme ? Never hear the name before. I log in the web, products seem impressive. Are the products original make in Germany?
Someone told me KS is same standard with Meyer Sound, true?.
Jamie Rose
Jamie
Steve Nichols
« Reply #3 on: November 15, 2010, 09:18:23 am »
Better is relative. All of the German stuff is built well. The KS appears to be top notch for sure. I chose the Seeburg because of the value.
They also have a speaker for every application. What are using them for?
Jamie Rose
« Reply #4 on: November 19, 2010, 02:14:27 am »
For Installation ; churches, multipurpose hall & so on
For Sound Rental company both indoor & outdoor application.
Seeburg ; Seems like a very good product and with good range. Design also unique.
The price range seems like in between KS & KME.
German made stuff always has a very clean top unit but problems with bottom; unless you're willing to purchase more bass bin to settle the low frequency issue.The configuration always recommended as 1 top 2 sub. For US or Italy made speaker the configuration is 2 or 4 top 1 sub.
You are right, Seeburg is value for money compare to KS.
Jamie
Steve Nichols
« Reply #5 on: November 19, 2010, 10:18:08 am »
Check out the G-Sub with the 1800W 18" driver with a mechanical excursion of 70mm. I have a couple come for testing I will post a review.
I can tell you that the TSM SUB DP+ 15" amplified unit with DSP works well. 1000w for the lows and highs with DSP and X-over. I use them with the A6 12" 2way tops.
Page created in 0.022 seconds with 18 queries.
