Pages: [1] 2 3  All   Go Down
Author Topic: Built a new t18 and it sounds like garbage! p.s im a noob -_-  (Read 13531 times)
ryan alli
« on: August 29, 2010, 11:47:04 pm »
I recently built a new t18 box for my evx180b subs with these specs  http://www.nrgrecording.de/html/t18.html Problem is, they sound great at lower volumes (150-200 watts) but at a little higher volume they sound all distorted! (500 watts). I tried using a new evx180a I had lying around and it did the same thing! Any suggestions?
Re: Built a new t18 and it sounds like garbage! p.s im a noob -_-
« Reply #1 on: August 30, 2010, 07:28:25 am »
Saying that it sounds like garbage really doesn't give much to go on.  Maybe if you could tell us a bit more aobut how it really sounds-for example-slapping sound-cracking sound- floppy sound-no bass- no highs (in the bass range)-distorted and so forth.
It oculd either be the cabinet or the driver or a combination.
dB Audio & Video Inc.
Paul O'Brien
« Reply #2 on: August 30, 2010, 12:39:09 pm »
The EVX180B is not a sub driver by modern standards, and the T18 isn't much of a subwoofer with response that only extends down to 50hz, so maybe you are expecting more than this design is capable of delivering.
Paul O
ryan alli
« Reply #3 on: August 30, 2010, 07:53:16 pm »
its a flopping sound
« Reply #4 on: August 30, 2010, 10:30:35 pm »
ryan alli wrote on Mon, 30 August 2010 19:53
Where do you have your highpass filter set?  You may be driving below its tuning. All loudspeakers will flp around when you do that.
John Halliburton
« Reply #5 on: September 08, 2010, 07:39:49 pm »
Ivan Beaver wrote on Mon, 30 August 2010 21:30
Or there is a leak in the cabinet.
John
Tim Weaver
    • http://www.weaverimaging.com
« Reply #6 on: September 10, 2010, 02:04:39 am »
Congratulations! It sounds like you built the T18 correctly because thats what they usually sound like....
Its really a bad, bad loudspeaker and could never be called a real subwoofer.
Jimmy Wright
« Reply #7 on: September 21, 2010, 02:37:52 pm »
+1
Set Highpass, check for air leaks, build something else
Try a T48 from Bill Fitzmaurice
"Who needs overheads? We have 58's on vocals"
"If you can't hear the subs, try moving 4 feet"
BFM T39-Best investment of my life
Kevin Unger
« Reply #8 on: September 26, 2010, 10:50:13 pm »
Tim Weaver wrote on Fri, 10 September 2010 07:04
Heard/Built one?
I have an AT here loaded with the recommended TangBand 8inch and it sounds great in a car, with very little power.
Replaced two kenwood 10 inch "subs."
t18 is a tiny sub designed for small rooms and to be corner-loaded. I don't get all the BFM knocking on here, when all the cabs perform as the graphs show on his site; and allow us diy'rs to build tested, easy to build cabs with a budget in mind.
Art Welter
« Reply #9 on: September 27, 2010, 02:21:22 am »
Kevin Unger wrote on Sun, 26 September 2010 20:50
Heard/Built one?
Kevin,
The T 18 bass box referenced in this thread is a lousy bass box made by EV, not a lousy BFM box.
BFM's graphs would be much more believable if they were not hand drawn.
Pages: [1] 2 3  All   Go Up
Page created in 0.023 seconds with 21 queries.
