Author Topic: what's the difference between SM58 and PG58  (Read 39341 times)
Dave Potter
    • http://www.dave thebass.com
« on: August 24, 2010, 06:38:54 am »
Presumably its the same capsule.
"When he wakes up, think of something cool.  Tell him I said it" ( Buffy)
www.davethebass.com
www.myspace.com/theswatbanduk
Fred Merkle
Re: what's the difference between SM58 and PG58
« Reply #1 on: August 24, 2010, 06:43:30 am »
Dave Potter wrote on Tue, 24 August 2010 06:38
They do not use the same capsule.  The difference is one sounds like it costs less...
Good luck.
-Fred
Dave Potter
« Reply #2 on: August 24, 2010, 07:43:35 am »
Hmmmm.  It doesn't make sense to make 2 capsule of the same size.  Particularly since the raw materials cost peanuts.
www.davethebass.com
Matt Vivlamore
    • http://www.meerkatsound.com
« Reply #3 on: August 24, 2010, 07:50:06 am »
I always see the PG58 used as a Talkback mic when touring companies come into town.
PG58 sounds like butt
SM58 is an industry standard
Beta58 is "better" than a SM58.
Find us on the web at: meerkatsound.com
I'm using: EV QRx212 over JBL SRX718s(2) with Crown IT's and MRX512m & MRX525 on monitors with XTi's; all controlled by Yamaha LS9-32.  I have a bunch of other stuff too.
Dave Dermont
    • http://www.geocities.com/livesound101/
« Reply #4 on: August 24, 2010, 08:45:16 am »
Dave Potter wrote on Tue, 24 August 2010 07:43
Have you ever considered why there are more than, say, half a dozen microphones being made in the world, and why some cost $35.00 and others cost $3,500.00?
Dave Dermont - Chief Lizard, LAB Lounge
WARNING: Dates In Calendar May Be Closer Than They Appear
Marlow Wilson
« Reply #5 on: August 24, 2010, 09:08:41 am »
I suspect one is made in China while the other is not.  It's hard to keep up with what's been moved over to China, but I can assure it's cheaper to produce microphones their regardless of other product lines made in Mexico or elsewhere.
I should probably be doing something else right now....
Thom "Fig" Fiegle
« Reply #6 on: August 24, 2010, 10:58:56 am »
Dave Potter wrote on Tue, 24 August 2010 06:43
Make microphones do ya?
There is little, if anything, in common between the two models - including the intended market(s).  The capsules are not based within each other's design goals.  Even the ball-grilles are not interchangable.
Shure made ANOTHER microphone, in a DIFFERENT series (PG instead of say, SM or Beta) at a LOWER COST so that "a Shure sound" could be attained by those who can not afford (or justify the cost, maybe?) of a $100 SM-58.
It IS avialable with a switch and quite useable as a FOH/MON talkback or occasional Djembe pickup.
I bet it ROCKS a karaoke hut!
Osci-later,
Fig
The easiest thing to do is the thing most easily forgotten.
Brian Jojade
« Reply #7 on: August 24, 2010, 11:06:24 am »
I've got both.  The SM58 is, well, an SM58.  Everyone knows it for it's workhorse ability and near indestructibility.  It's a good solid mic.
The PG58 is a cheap look alike.  Much worse for handling noise, not as tough, etc.  It's a $50 mic versus a $100 mic.  In the audio market, you get what you pay for.
Brian Jojade
HappyMac Digital Electronics
http://www.happymacshop.com
Tony "T" Tissot
    • http://www.4dbsound.com
« Reply #8 on: August 24, 2010, 11:09:08 am »
What's the difference?
It isn't as annoying when PGs are destroyed by punk bands acting like animals.
MNGS
ProSoundWeb - Home of 50,000 audio professionals - and two or three curmudgeonly SOBs.
Dave Potter
« Reply #9 on: August 24, 2010, 01:32:21 pm »
Well, I'm not a full time pro sound man.  What I AM is a full time professional Manufacturing Engineer so this is pretty much my area.
China isn't poor quality because they make things badly.  China makes poor quality because they cut corners in their processes and materials whenever they think they can get away with it (although I'm not sure that they actually think about it).  If they use the right materials (verified) and are held to correct processes with the same design then what you get is the identical product for less money.  So a PG isn't a PG just because its Chinese.
Are there any dynamic mics that cost $3,500?  No.  There are condenser mics for that money, but they are completely different.  A dynamic mic is:- a diaphragm, a coil of wire, a magnet a plastic moulding to put it in, a hand grip, a basket .  In he case of the SM series a transformer.
Once you have the processes sorted (they've been making the unidyne for decades) wire is just wire.  Its cheaper in bulk.  Moldings are just moldings.  It is not uncommon for companies to design exactly the same parts into cheaper products.  In some companies I've worked for, they built exactly the same product but disabled the higher functions.
I'm not arguing that they ARE the same (hence the question), just saying that in terms of manufacturing cost, it would be possible.
Anyway ..... I've no intention of owning one.
www.davethebass.com
Page created in 0.046 seconds with 18 queries.
