Pages: 1 2 [3]   Go Down
Author Topic: Dislike Powercon?  (Read 6832 times)
Jay Barracato
Re: Dislike Powercon?
« Reply #20 on: August 21, 2010, 11:45:47 am »
Looks like a OA Windsor to me.
Jay Barracato
Solomons MD
Tony "T" Tissot
    • http://www.4dbsound.com
« Reply #21 on: August 21, 2010, 02:17:26 pm »
Rob Spence wrote on Sat, 21 August 2010 08:40
Matt Errend wrote on Fri, 20 August 2010 20:57
Personally I love the powercon connector. For inlets on equipment I would much prefer them of a IEC connector, even a locking one. L15-20's are expensive, chunky, and uncommon and 5-15 edisons are to easy to pull apart on accident.
This is also a fantastic idea, particularly if you're running powered wedges with powercon inputs (Meyer UM-1P's for example):
http://www.oawindsor.com/images/powercon.jpg
Where did the boxes come from? I like them.
As mentioned, they are OA Windsor.
Ken at OA Windsor is a very helpful guy and makes a killer product. I built a few stringers and singles with their rubber boxes.
I am prototyping a stage monitor stringer (NL8 in and through, with NL4 outlets) with his assistance. I will document the result after the fall when I get some extra time.
MNGS
ProSoundWeb - Home of 50,000 audio professionals - and two or three curmudgeonly SOBs.
Jeff Wheeler
« Reply #22 on: August 21, 2010, 02:39:02 pm »
Derek Shawver wrote on Fri, 20 August 2010 16:13
So does that mean that Speakon connectors are awful as well? It's the same concept.
Neutrik specifically says, speakON is NOT to be used as an AC mains connector!   http://www.neutrik.com/us/en/audio/210_1380446656/NLT4FX-BAG _detailtechnical.aspx?title=NLT4FX-BAG
Jeff Wheeler, wannabe sound guy / moonlight DJ
John Livings
« Reply #23 on: August 21, 2010, 04:58:59 pm »
When dealing with 120v AC 15 or 20 Amp
Many people make the comparison  between a .59 cent Home Depot Duplex Receptacle and something "Locking".
The same is true for IEC connectors.
I use Hospital Grade Plugs, Receptacle, and Switches,(Also sold by some Home Depots) they cost about 10 times more then the cheap stuff, However they stay put when you plug things in ( and last a long time).
If someone trips over or gets something hooked on a cable, the last thing I want
is a small piece of plastic sticking out 4 or more inches, waiting to be snapped off.
If Edison plugs and Receptacles are loose or falling out, Replace them with good quality parts.
The same can be said for IEC Plugs and Receptacles.
I carry a few spares, but its nice to know replacements are close by.
I have gone to venues that a wall outlet has been broken , $6.00 and 5 minutes later, Power.
Just my opinions on keeping it simple.
John
Derek Shawver
    • http://Myspace.com/imadwumma
« Reply #24 on: August 22, 2010, 08:29:30 pm »
Jeff Wheeler wrote on Sat, 21 August 2010 13:39
Where in my post did I say anything about using Speakon for A/C?
-Derek
Will mix for food.
Proud owner of EV Phoenix and Crown I-tech.
Dan Richardson
« Reply #25 on: August 23, 2010, 10:47:22 pm »
Joe Brugnoni wrote on Fri, 20 August 2010 12:20
I wish the QSC K series had the power cons on them so I could build my own power cords for them,  the ones they send really suck to hide on stage when they are used as monitors, they will not coil or lay down with out gaff tape.
I took the bonus Euro Ac cables that came with my K series,
cut them off at 2', and put Edisons on them.
I use multiple output stringers and only need short runs for mons.
I still would love to see QSC start using decent cable, though.
That pre-kinked stuff is awful.
dut duruduttdurudutt dut dutt. I hate iphones.
(Brian) Frost
« Reply #26 on: August 26, 2010, 11:50:14 am »
I use mine to make an edison Y to one long and one short locking IEC so that my front stringer can supply power to 2 wedges up front.
Frost
Owner, Narnia Productions
www.NarniaProductions.com
Chicago IL
Good is good but not as good as better
Pages: 1 2 [3]   Go Up
Page created in 0.016 seconds with 14 queries.
