Jonathan Heimberg wrote on Tue, 17 August 2010 10:04 |
Just curious,
I'm not much of a woodworker, and though I've been lusting after lab subs for more than a few years, until I can buy them pre-made or hire a carpenter, it's not going to happen.
On the other hand, I've got a couple pairs of Black Widow 18"'s laying around that I was about to dump. Then I thought, why not put them in a couple dual-18 boxes for kicking around "C" rig stuff.
What would be (or where would I look) for a basic dual-18" plan that would work with these drivers?
Thanks in advance,
A Push-Pull Slot-Loaded (PPSL) would be helpful in removing some of the upper end and reducing the second harmonic distortion those musical instrument speakers have. A “V” load can be used also, reducing the plenum volume, thus reducing cabinet size slightly, but making the construction slightly more difficult due to those pesky angle cuts.
The “backwards” cone polarity must be reversed, both cones “push” forward into the plenum with positive voltage applied to the positive terminal.
The rest of the cabinet works as normal, size and tuning as Paul O’Brien suggests could be determined from a Peavey enclosure.
A deeper plenum will tend to roll the top end off lower.
Going with a larger, deeper port of the same tuning is beneficial, many of the designs of old (and new..) use too small ports.
