Author Topic: I-Tech DSP question  (Read 765 times)
J. Stanton Steward
I-Tech DSP question
« on: July 28, 2010, 11:17:25 pm »
I'm setting up a delay stack which will be 250 feet from the main PA.  The delay stack is comprised of 2 SRX728 and 2 SRX725 powered by 2 IT6000's.  I'm running the 725's passive/full range.  I'm using the itechs' dsp for x-over, peq, limiter and input delays.  I'm daisy chaining the I-techs together so that I will only be feeding the delay stack with one input.
I've set a 250 foot input delay on the I-tech which recieves the initial feed input.  Since I'm daisy chaining the i-techs together, does that delay transfer to the second amp or does the signal pass completely unaffected so that I would need to set a 250 foot delay on the second amp as well?
Everything I've read tells me the signal is passively passed through with no dsp on it, but I just wanted to make sure I'm not completely wrong or missing anything.
Thanks in advance.
J.
________
"I don't know anything about music. In my line you don't have to." --- E. Presley
Re: I-Tech DSP question
« Reply #1 on: July 28, 2010, 11:19:44 pm »
J. Stanton Steward wrote on Wed, 28 July 2010 22:17
Thanks in advance.
The text in bold is correct.  No processed signal appears at the channel loop-through outputs.
Have fun, good luck.
Tim Mc
J. Stanton Steward
« Reply #2 on: July 28, 2010, 11:28:48 pm »
Thanks, Tim.
J.
________
Page created in 0.024 seconds with 15 queries.
