Well used the SM60f this weekend at three different venues,still when i push the rig hard the cabinets are still going off.
I have removed anything that could be the fault....
Patch panel removed....So to connect straight to the back of the amps with speaker cables.
32 amp distro unit removed to see whether my amps were overloading that and dropping out.I placed 2 amps on one extention four way.The other amp on another extention cable.Into seperate wall sockets.
performing excellent until you pass a certain point then drop outs?????????
In the EAW KF695 that i used to use there is a passive crossover that eats power and gets hot???????
could the crossover's in the SM60f get hot with too much power and shut off?????????
if i drop the level down slightly on the master faders then we get no dropouts.Now it cant be driver failure as they would just burn out.
Im putting a FP6400 Lab Gruppen on the subs =
2300@4ohmsIm putting a FP3400 Lab gruppen on the tops =
1450@4ohmsIm Putting a 4000c Lab gruppen on the SH100 -4 MLS 600
watts@8 ohms
The subs seem content with the 6400 and dont bat an eyelid at the power but the tops when driven hard don't like it.
If say i dropped the amp that drives the tops to 1100 watts per side by cutting -2mls on the lab gruppen would that help??????
I currently have the crossover set at 90hz for both subs and tops on a 24db butterworth,would it be wise to raise the crossover point higher so that there isn't as much low energy going to the tops.
reguards Leon
