I bought a technostrobe to compare with my colorpallettes.
The TS is about 85-90 percent as bright as the CP. It also has the (what I see as an) advantage wherein the RGB channels don't get broken into pixels like the colorpallette.
You see, on the CP you use channel 1 to set how many pixels you see on the device. Unfortunately they put the 1 pixel option on the 255 value of that channel. So now you have to park that channel on 255 for each fixture you have IF you want it to be a color wash. If the 1 pixel option was at the 0 value for channel one it would be a non issue! Now if your console doesn't have parking functions you're screwed because any time you record a scene, you'll be fading that first channel through all its values until it hits full intensity and makes the whole panel come on. STUPID!
The TS on the other hand does the same thing, except that it doesn't have seperate pixels. The first channel sets the fixture functions by; solid RGB, then presets, then sound active mode. So you see, that by leaving the first channel of the fixture alone you get a standard RGB wash light! Yay! The TS is a 6 channel light. Function, R,G,B, strobe, and dimmer.
Combine all of that with the fact that it's quite a bit cheaper and that makes the TS a hands down winner for me if you intend to use it as a wash light and you use a decent console. If you plan on using the presets, I think its a little schizoid for me. I prefer the standalone presets in the CP's.
But hey I'm using them for a country band. What do I know!....
