Quote: |
How does an equally sized amp perform in the same circumstances? My guess is that 300w. isn't enough for your needs. What were you powering the wedge with previously?
Tim,
Up to now I have been using an old Yorkville SR300 which is only rated at 110 watts for an 8ohm load. All I was running in my monitor mix was lead vocals and my vocal and nothing else. I thought the IPR1600 would be a reasonable step up from that unit as far as power output is concerned. Basically anytime I ran a signal to the IPR1600 the DDT lights came on right after the Signal light lit up. To be honest the SR300 puts out WAY more than the IPR1600 does, I am thinking my new amp has an issue. I also switched to a PV112M alone, same issue. Also connected both the 15" and the 12" wedges and tried it running that 4 ohm load with the same results. Signal light on, turn it up a bit, DDT light on, sound off. BAH!
It made for an interesting first set anyways. Just unplugged the damn wedge and played and sang my parts.
For the remainder of the night I used one side of a Crown XLS202 that I usually run bridged for the bass players wedge. Set it back to stereo and had my wedge for the rest of the night. The Crown is a 200W @ 8 Ohm stereo, 600W @ 8 ohm bridged amp, it worked fine.
Marjan,
Thanks for the link, after reading it I am curious as to how you feel that relates to my problem? I must have missed something in that thread and the linked review? The 8 ohm performance in the linked article is more that twice what my old monitor amp was capable of, and it worked fine with the same wedge.
Thanks so far guys!
James
