Cody Hazelwood wrote on Tue, 23 March 2010 00:55 |
The amp is quite noisy (I'm assuming because of the DSP).
A studio environment is completely different than the stage monitor use the OP is asking about.
Just to make sure I wasn't ignoring something that I never listened to before, I got an XTi 2000 and some wedges out. The amp's noise floor is quite low, so much that the pink noise generator at -80dB is easily 30dB louder to my ear. I'd say that is acceptable for a wedge amplifier. While the broadband pink noise is easier to hear than the hissing it makes when there is no signal present, the noise with no signal present would be inaudible on any but the quietest stage.
How nice would it be if musicians were bitching about monitor amps with a -110dB noise floor, instead of the monitors never being loud enough to cut through the 600 watt bass rig?
I did fool around with the amp a bit to see what configuration changes affect the noise floor. I discovered several things:
* input trim by USB or front panel knobs has no affect
* bandpass gain has affect
* output EQ has affect
* input mute eliminates all noise
* shorting all the input connectors to ground has no affect
* input EQ seems to have no affect
* girlfriend's dog does not like pink noise generator
I think the noise in my unit is mostly 5kHz - 10kHz. I did fool with the output EQ and bandpass gain to put some bounds on this since my hearing is imperfect, as is the loudspeaker. I can't speak to the relative level of the noise because my hearing is subjective. If you wanted to know that, you could hook the output terminals of the amplifier to an objective measurement tool. I am guessing amp companies do that before they write the spec sheet and claim the noise floor is -100dB.
If you wanted this amp to play at low volume with less noise, I suppose you could reduce the apparent noise by reducing the bandpass gain. Obviously this would prevent you from being able to drive the amp to full power, but I would think a fan-cooled amplifier would be unacceptable for a studio anyway. I know the fan in my computer is way louder than the noise from this amp/speaker.
