Author Topic: 42" 720p or 1080p?  (Read 2441 times)
Jon Bannan
42" 720p or 1080p?
« on: February 24, 2010, 10:27:46 pm »
So I'm having the discussion with our consultant on a current project regarding a digital signage system.  The originally spec'd product no longer exists so we are in the current process of identifying a new product.  Basically looking for a player that resides behind the display and is connected to via our campus network.  The original spec called for a player that was identified as 1080p.  A couple of the products that we are looking at now are 720p.  So the question I have, on a 42" display that is broken up into sections, do you think that we'll see a difference between 720 and 1080?
Give me more coffee and no one gets hurt
Brad Weber
Re: 42" 720p or 1080p?
« Reply #1 on: February 25, 2010, 08:10:07 am »
By "broken up into sections" do you mean like a quad split or more like a video window with a graphics crawl below and some other graphics off to one side that is created by a processor?  What is the display's native resolution?
Brad Weber
muse Audio Video
Jon Bannan
« Reply #2 on: February 25, 2010, 08:21:50 am »
Hey Brad,
I expect like a video window with a graphics crawl below and some other graphics off to one side that is created by a processor.  I just double checked and realized that it's a 40" LED not 42" as I originally thought.  It's the Samsung LED UN40B7000.
Brian K Tennyson, CTS-D
    • http://www.visitec.com
« Reply #3 on: February 25, 2010, 04:20:19 pm »
No. I do not think you will see a distance if you are more than a couple of feet from the display.
You can't get enough, but enough ain't the test.
Brian Kent Tennyson, CTS-D
Visitec
www.visitec.com
« Reply #4 on: February 25, 2010, 04:23:12 pm »
Here is a great article on the subject from Carton Bale. Even has a Chart!
http://carltonbale.com/1080p-does-matter
Visitec
www.visitec.com
Jon Bannan
« Reply #5 on: February 25, 2010, 06:27:51 pm »
Thanks Brian!
Brad Weber
« Reply #6 on: February 26, 2010, 08:03:27 am »
That information addresses the aspect of looking at a 1080p or 720p native resolution image, however I don't believe that it addressed that the display is native 1920x1080 and will be upscaling a 720p source in order to fill the screen.
It might also be worth noting that the Samsung display model noted seems to be a consumer product and the warranty is specifically limited to noncommercial applications, which typically means anything other than consumer/residential applications.
Brad Weber
muse Audio Video
Page created in 0.036 seconds with 19 queries.
