Author Topic: A good, loud, intelligible outdoor PA horn?  (Read 4647 times)
John_Lackner
    • http://www.soundsystem.la
« on: February 01, 2010, 10:33:13 pm »
I'm in the process of spec'ing an outdoor PA announcement system that needs to cover a baseball field - with one or two horns. Just announcements only - no music. I noticed there's dozens to pick from. Any personal favorites? Something that would match up with a Crown 160MA or something similar.
Also, another question - if it's only one horn would it be better to wire it 70 volt or 8 ohm if the cable run is about 40 feet?
Tim A Perry
Re: A good, loud, intelligible outdoor PA horn?
« Reply #1 on: February 01, 2010, 10:58:14 pm »
John Lackner wrote on Mon, 01 February 2010 22:33
It will be pretty hard cover what you need with one horn, you probably want to get the stands plus at lease some of the field.
A single point cluster of horns might be practical depending on what you have to work with. I.E light poles, press box, score boards, etc.
Atlas Sound makes a wide range of units that should fit your needs.
If someone mentions Speco just hit them with whatever is handy until they go away.
If possible always go with a 70 volt system as nearly always someone gets a bright idea to add to the system sooner or later.... like the boosters want to hear the announcements while working in the concession stands.
"Music washes away from the soul the dust of everyday life" ~ Berthold Auerbach
« Reply #2 on: February 02, 2010, 07:43:59 am »
Are you trying to cover the field or the audience area-or both?
Most systems try to keep energy off of the field and only on the audience area.
That will make a big difference in which way you go.
Define your target FIRST, then look for the proper tool.
dB Audio & Video Inc.
Brad Weber
« Reply #3 on: February 02, 2010, 12:23:26 pm »
To add to Tam's and Ivan's comments, considerations such as providing the required level to all listeners, and perhaps not to where you don't want it, should be the driving force behind selecting the speaker(s).  Without knowing the potential speaker locations, the areas to be covered and so on, there is not much basis for any specific recommendation.
If they just want something to make sound and don't care if it can actually be heard or understood, then one speaker is probably as good as another, it may end up replaced soon anyways when they decide they do actually want everyone to hear and understand what is being said.
Brad Weber
muse Audio Video
John_Lackner
« Reply #4 on: February 02, 2010, 01:27:55 pm »
It would be primarily for making announcements to players on the field. There's no audience area, and the horns will be mounted on top of the snack bar next to the field.
« Reply #5 on: February 02, 2010, 05:37:56 pm »
John Lackner wrote on Tue, 02 February 2010 13:27
We have no idea where the snack bar is-maybe you do? Rolling Eyes
If it is behind home plate-then a single horn will probably cover the area fine.
Be sure to get it up high enough so you kill the people around home plate.
Edit-snake/snack-same thing to some people around here. Laughing
Art Welter
« Reply #6 on: February 02, 2010, 07:35:14 pm »
Ivan Beaver wrote on Tue, 02 February 2010 15:37
You have something against umpires or catchers, Ivan Laughing ?
« Reply #7 on: February 02, 2010, 08:46:48 pm »
Art Welter wrote on Tue, 02 February 2010 19:35
I don't know if helping to protect their hearing will help their eyesight or not-but it can't hurt Laughing
Brad Weber
« Reply #8 on: February 02, 2010, 09:54:04 pm »
Ivan Beaver wrote on Tue, 02 February 2010 17:37
We have no idea where the snake bar is-maybe you do?
Right next to the iguana lounge?
Brad Weber
muse Audio Video
« Reply #9 on: February 03, 2010, 07:45:26 am »
Brad Weber wrote on Tue, 02 February 2010 21:54
I've edited it.  But to some people around here-it is the same thing Laughing .
The Snake bar-is that a gay club? Rolling Eyes
Page created in 0.079 seconds with 21 queries.
