Hello,
I recently tried my hand at repairing one of my sub cabs due to water damage (burst pipe). It's a Community CSX40-S2 made of particle board. Basically this was the cab on the bottom of the stack that soaked up water and the joint came apart (warped).
I thought I could just unload it and put some glue into the joint and screw it together. Well, needless to say I ended up taking the carpet off the entire cab to evaluate things. I pried the joint open put some glue in and screwed it closed. I predrilled some holes around the entire cab joints and reinforced those joints as well with screws.
After the glue dried, I decided to put some Lexel (like a silicone sealant) around all the inside joints as well. When this dried I painted the entire inside of the cab flat black.
Sorry for the blabbering, here's my questions.
1. With painting the inside of the cab and using the Lexel, could this change the frequency response of the cab at all? If it does, wondering if I should do the same to the good cab so they both match.
2. I reinstalled the fiberglass using staples as this is how Community did it also, but the staples shot through the glass in some spots and I'm afraid it may come loose. What would be a good way to hold the glass in place? I was thinking on little screws and plastic type washers.
Oh, I actually reinstalled the same carpet that came off the cab with using 3M Super77 spray adhesive. It seems to be holding really good. I wont be gigging with these cabs anymore, but just wanted to try and fix it up for home & friends parties (DJ'ing).
