Why do you have a crossover and a DRPA?
I would suggest 4 rack cases...
Rack 1
1sp Input panel with 2 XLRs inputs on it
DRPA
2sp FOH Amp
2sp Sub Amp
Rack 2
DRPA (get yourself another one, they are cheap).
2sp FOH Amp
2sp Sub Amp
Rack 3
1sp Crossover (i assume this its for monitors)
4sp empty for future expansion
2sp Monitor Amp
Rack 4
(3) 1sp Compressors
1sp Power Conditioners (you don't need one of these in your amp rack)
1sp Effects Processor
2sp Dual 31 band EQ
1sp Recording Interface
Doing this gives you a lot more flexibility.
You can now either use your FOH amp racks on two seperate jobs, or you can put one on each side of the stage to avoid long speaker runs.
Having a DRPA in each rack either allows you to just send a single signal feed to each side of the stage, or you can do two jobs at once.
I would highly recommend making the amp rack cases extra deep (deeper than the amp) and putting rack rails on both the fron and back. Also, leave at least an extra 2 rack spaces for when you want to go to a 3 way system
It could be handy to have another space with XLR socket mounts for the inputs so the signal inputs are on the front of the rack.
On the back rails, you can put a permanently wired power input so you have no flat pin power points to come undone and also you could put some panel mount speakon outputs with both NL4 and NL2 options for flexibility.
Building your amp racks right is worth the investment and its worth thinking long term. It can save an awful lot of time in setup if they are well built and it also makes them more reliable.
Make your 3 amp rack cases the same size, one day you will want more monitor amps so having space in the monitor rack to add more amps later is a good idea.
