Pages: [1] 2 3   Go Down
Author Topic: need about 40' single phase feeder cable  (Read 7360 times)
Joe Montes
« on: January 26, 2010, 03:26:43 AM »
need about 40' single phase feeder cable, can somebody point me in the right direction for the best deal? can I use welding cable? it will be feeding a 100a distro
thanks
Matt Vivlamore
    • http://www.meerkatsound.com
Re: need about 40' single phase feeder cable
« Reply #1 on: January 26, 2010, 07:50:20 AM »
You should be looking for SO type cable.
What kind of jacket is on welding cable?
As for gauge, I would look at 4. your standard Range plug from Lowes is 6.
Best deal; depends on your location.
If you on the East Coast, check out Camel Traders.
Find us on the web at: meerkatsound.com
I'm using: EV QRx212 over JBL SRX718s(2) with Crown IT's and MRX512m & MRX525 on monitors with XTi's; all controlled by Yamaha LS9-32.  I have a bunch of other stuff too.
Jay Barracato
« Reply #2 on: January 26, 2010, 07:55:32 AM »
Lowes only stocks SJ but Home Depot stocks SO. I am not sure what the largest size they have in 3 conductor is but I have bought plenty in 10-14 gauge.
Jay
Jay Barracato
Solomons MD
Rob Timmerman
« Reply #3 on: January 26, 2010, 08:46:30 AM »
Matt Vivlamore wrote on Tue, 26 January 2010 07:50
NO.
At 100A, you are using either pin+sleeve connectors ($$$) or single pole connectors (Cam-lok).  If you use pin+sleeve, you can use type SO (assuming you can find 2AWG 4 conductor cable - and it's only rated for 95A).  Otherwise, you need to move to type W (again 2AWG or 4AWG 4 conductor cable, depending on temperature rating).  If you are using single-pole connectors, you need to use either type W or type SC, and can use 4AWG or 2AWG.
Joe Brugnoni
« Reply #4 on: January 26, 2010, 09:59:02 AM »
Your better to use single strands of #2  than a jacketed SO cord with all 4 wires inside. It increases the capacity per the NEC so you might be all right.
Be nice to everyone as you can learn something from anybody
dustin Bradley
    • http://www.myspace.com/drumdogman
« Reply #5 on: January 26, 2010, 10:39:13 AM »
i agree with the banded camlocks of 2awg sc cables
 http://www.lexproducts.com/cs/industrial_product?id=354& market=Industrial&productLineId=17#
~ dustin B
Matt Vivlamore
« Reply #6 on: January 26, 2010, 11:57:17 AM »
Rob Timmerman wrote on Tue, 26 January 2010 08:46
NO.
Opps... I didn't see that 100a... I was thinking for a small power disro using the 14-50 plug.
Todd Black
« Reply #7 on: January 26, 2010, 12:12:29 PM »
Joe Montes wrote on Tue, 26 January 2010 02:26
thanks
cant use welding cable as feeder cable. It was banned many, many years ago. Type SC is what you want. You can use type W but it is much more expensive, heavier, and difficult to work with.
SO cable would have to be used with pin and sleeve connectors (or
another multipin connector) Its not to code to 'fan out' a multiconductor cable and put camlocks on the ends. The individual conductors inside SO cable carry no ratings, not to mention its dangerous as the insulation is easily damaged. Last, you cannot have a single conductor feeder smaller than #2, except for the ground where #6 is permitted.
Joe Montes
« Reply #8 on: January 26, 2010, 01:39:35 PM »
thanks alot for all the very helpfull info guys, yes I prob should have made it a little more clear. I do need the four single feeds (red,black,white,green) bare wire at one end and female cam-lok at the other end approx 40' feet of it.
thanks
David Little
    • http://www.dblittle.com
« Reply #9 on: January 26, 2010, 01:48:50 PM »
Historically we used J-Custom Supply.
http://www.jcustom.com
They had best price/quality. Granted it has been nearly ten years since I have been in the market, but that was the go-to for many of us in the southeast US.
David Little
http://dblittle.com
http://www.dblittle.com/catalog/images/dblit310x90b.gif
Pages: [1] 2 3   Go Up
Page created in 0.041 seconds with 21 queries.
