Jim Bowersox wrote on Thu, 24 December 2009 20:38 |
I have 2 questions for the SB people. I'm not looking for a load of marketing speak, but rather a legitimate explanation of the acoustic theories and principles behind the design.
1) What does the plastic mesh in front of the horn do?
and
2) What does the angle of the LF drivers do?
Inquiring minds want to know!
Regardless of explanation of the speaker positioning and the HF diffraction grate, the side by side arrangement and distance between the apparent woofer center to the mid/high driver center will result in an off axis dip around the crossover point between the two bands.
The dip is unavoidable. If this cabinet/array is EQd properly for a flat on axis response, the off axis response will show a “suckout” around the crossover frequency. The differing dispersion characteristics between the drivers will also make the “suckout” non symmetrical left and right.
The mid driver can go rather low, so one has a bit of latitude determining where the compromised frequencies will be, but the problem will occur, and any polar chart would clearly indicate the problem. Room reflections would mask this problem, but an outdoor measurement would clearly indicate it.
The Xyon cabinets are not alone in this problem, any manufacturer adopting a side by side low mid/high arrangement like this will have similar problems.
One can “blame” vertical problems in the HOB from a too short split array, but the horizontal midrange coverage problems are directly attributable to the driver horizontal spacing distance which will result in severe comb filter problems around the crossover point.
Art Welter
