Montez Carter wrote on Wed, 28 October 2009 16:37 |
These are Billfitzmaurice Tuba 36's 28 inch internal width all 1/2 inch baltic construction CNC milled all internal panels datoed and assembled with PL adhesive. I have swept them with sine waves and performed an impedence sweep on them so I am sure there ar no air leaks they are built exactly to plans. Not saying they are bad just not what I want at this point in my company's existance. I am just moving into a larger market now and when I play an SB 1000e (original or copy) they just sound linear throughout the passband. If you corner load the Tubas it seems to get a little better on the lower octave but that is not feasible in the 2000-3000 seat market that is paying my bills at this point.
The Lab Subs will meet your requirements. However, you need to bear in mind a EAW SB 1000/KF 850 will be more suited together since the frequencies can overlap amongst both cabinets. You may need to devote more energy in the low-midrange section of the KF 850 since the Lab Subs are not very useful above 80 Hertz.
Also, keep in mind Lab Subs like the SB 1000 will require more amplifiers from an 8-box Tuba 36 versus an 8-box Lab Subs or SB 1000 ratio. You cannot load all 8 Lab Subs on one amplifier as you can (if you do) with the Tuba 36.
And lets talk about power. The EAW KF 850 is a classic touring box and designed to go loud. You will need to have ample amount of amplification for the Lab Subs not because they are inefficient (they are not by any means) but based on the type of music you are reinforcing.
Hip Hop music offers a lot of SPL emphasis within the 35 – 40 Hz region and, at times will sweep into 30-Hertz. While the Lab Sub will have no problem delivering those frequencies with ease, you do need power to create that type of sound Hip Hop is known for.
Eight Labs under 4 EAW KF 850s will give you what you are aiming for.
Best Regards,
