Josh Ricci wrote on Tue, 15 December 2009 14:05 |
Jeff, Sounds like you are having fun with it. It's a cool kit to build and the output is pretty durn impressive. Especially the 10-30hz area. I think 2 is a good idea mostly because of the ability to smooth out the in room response more than the extra headroom, but that can be fun too.
Did you see the posts at AVS about modifying the "G" brace under driver 2 or using an extra gasket to give more clearance? Also the posts about adding some extra damping in the cab to knock down the out of band reflections in the cab? What amp are you powering it with? I'm running a bridged Crown CE4000.
Yes, I heard about modifying the brace, I'll have to pull the driver and check that out. It sounds like adding the extra gasket in front of the driver also helps with the possible clearance issue.
I haven't added an extra fill yet either. I figured that I would try it out first. So far I haven't really noticed adverse affects (in actual use).
Currently the sub is being powered by a QSC PL380 in bridge mode. I wired each driver to it's own channel of pins on a Neutrik NL4 connector on the input panel. One four conductor NL4 cable into the bridged PL380 and I'm in business.
Maybe I should get another one just for fun.
Jeff
