Pages: 1 2 [3]   Go Down
Author Topic: DIY 11Hz Tapped Horn in your Living Room?  (Read 18344 times)
Art Welter
Re: DIY 11Hz Tapped Horn in your Living Room?
« Reply #20 on: December 15, 2009, 04:47:20 pm »
Josh,
Thanks for posting the build pictures, quite the project.
What are the drivers used in the DTS 10?
Martin Queckenstedt
« Reply #21 on: December 15, 2009, 06:44:59 pm »
Art Welter wrote on Tue, 15 December 2009 15:47
The drivers are from Eminence and are a modified version of the LAB12.  I don't know if anyone has posted more information about them except:
- 3" voicecoil
- 500 watt RMS
- 15mm Xmax
« Reply #22 on: December 15, 2009, 07:06:18 pm »
They are custom built driver for Danley.  They are the same drivers that are used in the DTS-20, CS30 and TH112.
They basically look the same as a Lab12-but there are several major differences-the coil wire-the overall size of the coil-the cooling and so forth.
dB Audio & Video Inc.
Art Welter
« Reply #23 on: December 15, 2009, 07:13:51 pm »
100 watts more power, slightly more Xmax.
Do you know what the FS is?
Michael Hedden Jr.
« Reply #24 on: December 15, 2009, 09:56:33 pm »
When we were initially working on the DTS10 project, I asked Tom to model the LAB 12 in the sub and it doesn't come close to the same performance as our driver especially down around the low teens/single digit response.
Mike Hedden
Danley Sound Labs, Inc.
Jeff Knorr - Cobra Sound
    • http://cobrasound.com
« Reply #25 on: December 16, 2009, 10:00:16 am »
Josh Ricci wrote on Tue, 15 December 2009 14:05
Jeff,
Sounds like you are having fun with it. It's a cool kit to build and the output is pretty durn impressive. Especially the 10-30hz area. I think 2 is a good idea mostly because of the ability to smooth out the in room response more than the extra headroom, but that can be fun too.
Did you see the posts at AVS about modifying the "G" brace under driver 2 or using an extra gasket to give more clearance? Also the posts about adding some extra damping in the cab to knock down the out of band reflections in the cab? What amp are you powering it with? I'm running a bridged Crown CE4000.
Yes, I heard about modifying the brace, I'll have to pull the driver and check that out.  It sounds like adding the extra gasket in front of the driver also helps with the possible clearance issue.
I haven't added an extra fill yet either.  I figured that I would try it out first.  So far I haven't really noticed adverse affects (in actual use).
Currently the sub is being powered by a QSC PL380 in bridge mode.  I wired each driver to it's own channel of pins on a Neutrik NL4 connector on the input panel.  One four conductor NL4 cable into the bridged PL380 and I'm in business.
Maybe I should get another one just for fun. Smile
Jeff
Cobra Sound
An authorized Allen&Heath, Ashly Audio, Audio-Technica, Audix, Da-Lite, Danley Sound Labs, FBT, Mackie, QSC Audio, RCF, Sabine, Sennheiser, Whirlwind, and Yorkville Sound dealer.
Pages: 1 2 [3]   Go Up
Page created in 0.039 seconds with 20 queries.
