Author Topic: In wall speaker help  (Read 1433 times)
Nathan Short
    • http://www.myspace.com/nathanshort
« on: October 19, 2009, 06:27:30 pm »
Hey all,
I need something that could be on par with say a JBL Control 29av or control 30  in an in wall speaker format.  For side mounting into a hollow soffet in a restaurant.
I am looking at the control 300 series but don't know how messy side mounting a back box would be..  bla bla bla.
I want something easy, and relatively high output.
AIS Chicago--System Designer
Freelance FOH/Monitor/System Tech/Stage Manager/
Stagehand Lead/Production Coordinator/Sound Enthusiast/Speaker Design
WWW.MYSPACE.COM/NATHANSHORT
WWW.Facebook.com/NathanShort
Hal Bissinger/COMSYSTEC
    • http://www.comsystecusa.com
Re: In wall speaker help
« Reply #1 on: October 19, 2009, 08:54:42 pm »
There is a new Control 128 in-wall speaker. Never used it and I wonder how well it performs without an enclosure or back box especially if you compare it with the 29AV. It's pretty much a home in-wall speaker.
-Hal
Craig Hauber
    • http://www.csaproductionsinc.com
« Reply #2 on: October 20, 2009, 01:57:43 am »
Get a rectangular wood-cabinet speaker and build a flange of angle-iron.  Cut, weld, grind and paint to match and screw to the cabinet around the perimeter.  Use Toggler-bolts to mount in the wall, you may have to make a plywood ring to reinforce the drywall of the soffit to studs or structure from the inside.
I do know parts express has a blank-baffle inwall cabinet if you want to customize something yourself.  Unfortunately it doesn't have a back-box and the cabinet-less design of most inwalls is their biggest downfall.
I just remembered that EV has an EVID inwall 6.2 now too
http://www.electrovoice.com/products/602.html
(If it's like the other EVID models, they paint very easily if white isn't desirable)
Craig Hauber
CSA Productions Inc.
Ventura-Santa Barbara CA
Brad Weber
« Reply #3 on: October 20, 2009, 01:06:40 pm »
Did you look at the Control 128W in-wall speaker?  And although they may not have the same low frequency performance unless you also employ in-wall subs, I've had good luck with the Tannoy in-wall speakers.
Brad Weber
muse Audio Video
Page created in 0.06 seconds with 19 queries.
