Ivan Beaver wrote on Mon, 12 October 2009 17:01 |
Caleb Dick wrote on Mon, 12 October 2009 11:54 | Does this mean the TH-812, and possibly TH-212 will have the drivers swapped as well? Is there an automatic 1dB increase in output? If so, when will the website and spec sheets reflect these changes?
Caleb
Yes. The 812 will be using the same drivers as the TH412. We cannot do the same thing with the 212 as the internal size is a problem using the TBX drivers.
We are changing to the PS100 drivers as used in the TH mini-so the power will remain the same as before-but the 812 will go up.
The freq response curves are, for all paractical purposes, the same. With the exception of a little wiggle or squiggle the curves lay on top of each other.
Yes the website will be updated. When will depend on the IT dept.
Ivan, I just wanted to be sure I read you correctly (as it seems from the comments following yours above that most people didn't read you right - including myself).
You are saying that the TH-212
has also had it's drivers changed - only not to the TBX drivers like the 812 and 412, but instead to the PS100 as in the TH-MINI? So even if the problem was (/is for those with old TH-212s) not nearly as big for the TH-212, it has been altered. Correct?
Oh, and now that I'm at it: Will Danley be at Frankfurt this year? (Cause then I might be)
