Author Topic: FOH Frequency Response Curve  (Read 5946 times)
Chris Boschen Leonard
Re: FOH Frequency Response Curve
« Reply #10 on: September 28, 2009, 10:46:09 am »
+1 on dealing with the major variations using the DSP paraEQ. The DSP is waaaay more suited for making precise adjustments than a graphic, especially when you are working inside a SMAART window with inverted traces, so you can match the amplitude and Q of the filter to correct the trace.
When I tune a system, indoors or out, I am going for as flat a response as possible across the frequency range of the speakers. I do this via the DSP paraEQ, until SMAART shows acceptable traces. The dual 30 band KT Eq's I usually use on mains (I work mostly with small systems & clubs) are for the FOH, and are left flat. If the FOH wants a low end bump, they can hit the KTs. Essentially, the FOH gets two layers of processing: mine, and theirs. My DSP EQ settings smooth the response to a good starter setting, and then FOH talent can hack to their heart's content on the KTs if they want or need something different, for whatever reason.
I like to give a BE enough rope to hang themselves in style.
Chris Leonard
Principal,
Boschen Technologies
www.boschen.org
ZhaoLi Seow
« Reply #11 on: September 28, 2009, 11:22:38 am »
Well, I use Smaart for my measurements and to clarify, i have an imaginary line that is drawn at say +12dB at 20Hz and end at -6dB at 20kHz and i tune the system to match that line. It doesn't mean i have that line on the sliders on the GEQ. it's the system response shown on the smaart frequency analysis. Of course there is no system that is able to produce the extremes of 20Hz or 20kHz, and I will roll off the bass at a reasonable frequency and not push the trebles to extreme.
anyway, at the festival, I had the chance to observe the various artist's FOH engineer tune the system and look at their overall response curve. These are engineers for world class acts that have hits that top billboards.
Dick Rees
« Reply #12 on: September 28, 2009, 12:17:42 pm »
ZhaoLi Seow wrote on Mon, 28 September 2009 10:22
I learned long ago not to confuse "entertainment" with music (sound).
 Neo-Luddite, Rocket Surgeon
"Pay no attention to the man behind the curtain."
Karel 'Charly' Will
« Reply #13 on: September 28, 2009, 01:26:09 pm »
Hi,
Magu offered me his goal for system tuning: flat from as low as possible till around 100Hz, then a ten dB roll off till 1kHz, then flat again till as high as possible.
That's remarkable similar to what some of my more experienced colleagues are doing for rock and dance.
I notice that when I tune a system by ear, I get a result that is mostly flat as a ruler, but with a 10 - 12 dB bump below 100Hz. I think that gives me a much more hifi sound, better suited to folk, pop, ...
I guess rock and dance need that extra low mid in order to make the music being felt, where folk, pop, ... benefit from the extra clarity in systems that were tuned "flat".
Just my 0.02
Jason J Raboin
« Reply #14 on: September 29, 2009, 01:18:58 pm »
For me it depends on the act.  For louder rock a 6-12 db boost below 80 and a gentle roll off starting at 2k sounds good to my ears.
For the folk act, I am looking for flat, with a 3-6 db dip in the 2-4k range.  The size of that dip seems to depend on the quality of the PA as well as how much high end the PA puts out.  The less "air", the bigger the dip.
Timo Beckman
    • http://timobeckman.spaces.live.com/
« Reply #15 on: October 14, 2009, 03:18:51 pm »
I just start out with finding the x-over point between the main system and the subs (-6db point on the low end of the main). put in the low pass filter on the subs and take aa look at the freq responce of the system (sub and main) . Most of the time you see a dip appear in the 80 to 125/160 region of the pa meaning you have a combing problem (most systems i do have system settings for the tops  and as long as they are ok i do not worry about them ). Then apply delay on the subs and play around with it untill the dip is gone . Also i look at the phase trace before i do this and after the hole is gone .
Most of the time the subs are aligned with the mains at that time . After that i try to flatten the mains on all the areas where the freq responce is going above a centre line over the full freq responce of the system using gentel q factors on the parametric eq's .
I try to flatten the sound as much as possible so that what ever you do on the mix board comes out of the system .
After that i take a measurement of the mains at the possition of any delay/fill system there and try to match that to the mains in phase freq. responce and level .
I use a combination of smaart sat-live and my main analyzer is SIM3 with 6 DPA4007's wich gives me a lot of possibilities to verify all that i'm doing .
Greetz from a rather cold and windy place in the netherlands .
Christian Tepfer
« Reply #16 on: October 14, 2009, 06:37:49 pm »
Well, I basically don't care what frequency response I have on FOH.
I care about "does it sound good". When I measure the outcome it depends heavily on the source material, the room and the audience.
On PA systems I take what I get and try to mix accordingly. Makes no sense to try to push a system beyond the limits.
Eric Snodgrass
« Reply #17 on: October 14, 2009, 08:15:18 pm »
Christian Tepfer wrote on Wed, 14 October 2009 15:37
+1
Eric Snodgrass
No, really, I do this for a living.
Page created in 0.105 seconds with 21 queries.
