Gene Hardage wrote on Thu, 24 September 2009 23:20 |
or - does aux-sends-on-fader mode mean something else??
Aux send on faders means that instead of the faders being for your main mix only, you can select any aux mix to be displayed on the faders - really requires motorised faders to work though.
The advantage is that you
don't have to go through any layers etc to see and adjust your aux mixes - just hit the button to select that aux and there it is on your faders. Although it might not seem like it to an experienced analogue operator, it's
even easier than scanning along one row out of multiple aux knobs to see and adjust what's in a mix.
When you're doing things like that, having the faders snap into place to show each and every mix as you select them is pretty much essential, otherwise you have to move them all into place to match the visual indication yourself before you're really in a position to adjust them in a meaningful way. Or, you have to see past the actual position of the faders, which is now just a hangover from the last mix you were adjusting, and use only the visual indicators and adjust the faders of any channels which need changing in relation to those indicators and not in relation to their existing position.
In other words, it chucks away one big benefit of other digital desks.
Cheers,
David.
