Art Welter wrote on Thu, 13 August 2009 15:51 |
Jeff,
(Doppler distortion) caused by lower frequencies modulating the higher frequencies.
Art Welter
Hello Art,
First off, this is a good post, but I am in disagreement with this one portion.
I understand that you know more about speakers than me, but this has always seemed counter intuitive to me.
Basic physics classes taught us that when you add two waves together, IE a 100hz wave, and a 1khz wave, that you just add, or subtract, depending on the position of the curve, the two curves to get the final curve, which is a single complex curve, but the ear hears it as two sine waves. It is no different whether it is electronic, or physical, or on paper, the two sine waves are still as original, or as separate.
What will happen is the lower end of the spectrum will run out of poop, or clip, or have power compression, that will affect the high end. But, in a fixed system where the speaker box is not moving, there is no such thing as doppler distortion.
The best response to this was made by Tom Danley. Someone in the early aughts doubted the single horn of the td-1 and brought up this very point. He discounted it firmly, soundly, and thoughtfully. Much better than I ever could. Said that it would not happen until 147db when the air in the horn started to physically distort. And since the signal does not physically couple until the throat of the horn, there is no possibility of it distorting the signal from the driver, at the mouth of the horn.
So the same applies to a full system. The signals will couple whether they are in a single point source, or next to each other. The only time you will get doppler is if it is moving, IE on top of a bus, ambulance, etc, or swinging in the wind, not stationary from the original source.
Take that wikipedia.
Regards, Jack
