Author Topic: Passive splitting a line level signal  (Read 3464 times)
Joe Thierry
« on: August 03, 2009, 10:45:54 pm »
How many times can you passively split a line level signal without having issues?
Thanks,
Joe
Arthur Skudra
Re: Passive splitting a line level signal
« Reply #1 on: August 03, 2009, 10:53:01 pm »
It's determined by the output impedance of the "sending" unit vs. the combined input impedance of the "receiving" units.  Generally I try to keep it to no less than a 10:1 ratio input vs. output impedance respectively.
Some interesting reading here:
http://www.rane.com/note124.html
« Reply #2 on: August 04, 2009, 10:24:52 am »
Joe Thierry wrote on Mon, 03 August 2009 21:45
Thanks,
Joe
The answer depends on specifics about the products used, and how you define "issues".
Unless you are doing something unusual this is probably not a concern. Most professional gear is designed with adequately low output drive capability (not to be confused with output impedance) , and adequately high input impedance (which is exactly what it sounds like), to tolerate several splits.
I would be careful about less than professional gear which may not have much output drive capability, or oddball inputs with lower than normal terminations. If trying to split more than a handful of boxes check the data sheets and do the math.
For a good split the worst consequence a fractional dB insertion loss, for worst case, distortion on signal peaks and perhaps HF/LF loss.
 https://www.resotune.com/
Tune it, or don't play it...
Tim Weaver
    • http://www.weaverimaging.com
« Reply #3 on: August 05, 2009, 01:52:18 am »
Whirlwind feels very comfortable about splitting a signal up to 6 times.....
http://www.whirlwindusa.com/i1/splt6sh.jpg
Greg Cameron
    • http://www.cameronproaudio.com
« Reply #4 on: August 05, 2009, 03:04:46 pm »
You can likely go a lot more than that with many typical devices. ≥20kΩ balanced inputs are common and ≤100Ω balanced outputs are common as well. Of course like JR said, you have to check the specs for your particular items and calculate accordingly. But with say a 100Ω balanced mixer output and several amps channels with 20kΩ inputs, you could in theory split the mixer output into at least 16 inputs (1.25kΩ) and still maintain a 10:1 input to output impedance relationship.
Greg
Cameron Pro Audio.
Page created in 0.05 seconds with 21 queries.
