Chuck Harrigan wrote on Fri, 17 July 2009 15:32 |
Sorry, posting at 2 am is not recomended.
it looks to me like the first stage of the write stage is used to drive the second stage, which creates a high voltage signal that is stored in the capacitive oil drum. If the control pedal is a switch, it would mute the second half of the write stage, or if it was a potentiometer pedal, it would vary the strength of the signal being written to the oil drum.
The read stage looks similar to a phono preamp without the RIAA equalization. It is using negative feedback, and it also sends the output signal back to the input of the second stage of the write path. The potentiometers would be used to set the amount of signal being sent back to the write stage, as well as the output level. I'm guessing that the capacitor is used to decouple the output from the high voltage, so you aren't sending 450V to the next device in the chain. I think the echo level is setting the gain of the final stage through the amount of negative feedback.
Memory would be the oil can. It is rotating and the high voltage signal is being "written" to the plates or whatever is in there capacitively. The drum acts like a hard drive, but using charges stored in oil instead of magnetic plates to store the information. I'm thinking that the reading of these signals would be destructive.
edit: grammar
Chuck, and anyone else who understands tube pre amps and drive circuits,
As I wrote in my initial post, I have tried using pre-amps, small power amps, various input and output transformers, and can get lots of echos from my oil can, but the signal to noise ratio is about 1/1, actually more noise than signal. Oil can echos are normally noisy, but not like that. I do have fresh oil of the special kind (and quantity)that makes the device work in it.
I understand the device is always going to be a bit noisy, and since the disk is scratched, it also will always have clicks like a scratched record.
Is there anything that the electronics are doing in this circuit other than amplifying the signal going into the can and then amplifying the output?
What does this circuit do differently than all the stuff I have tried already?
Art Welter
