Ben Lawrence wrote on Mon, 15 June 2009 22:23 |
Just tested the 2000 which I unlocked today. Its got issues still. Signal bleeding on one of the channels even when all the way down (intermitent). Power LED not functioning. Back to the factory I guess. Let you guys know on the 4000s.
Signal bleed is LED only, or can you hear it on the other ch? The ribbon cable might need to be re-set. I had this with one of mine, and it fixed it. It was LED only.
I have another that I might have the inputs summed, but in bridge mono mode. It will show both LEDs as well with one input. I asked on crown forum a long time ago, and the reply was not very clear to me, and I let it go as It seems to be an LED thing only. I have 4 XTi, and only one is "bleeding". I just need to power it up at home and hook up my wifes PC to see if I have Y input. Might need to reseat the cable on that one as well. It was a known issue on early XTi's.
Post back when you get results.
