Stephen,
Messages #444077, #444087, #444251, #444275, #444286 and the linked article all point out that that when driven too hard, a speaker’s sound will change.
The changes should be apparent before the speakers are damaged, other than exceeding Xlim.
However, some music is so distorted to start with that it is hard to tell the difference when speakers distort.
Oh well.
If you have a decent set of headphones, you can compare the sound of your speakers to them, using the phones as a reference.
As you start pushing your speakers too hard, there will be a level where they no longer sound the same.
The speakers will be out of their linear operating range.
The point where you need more rig for the gig.
As speakers exceed Xmax, the woofers will distort.
Distortion sounds different than clean. A pure sine wave will start to sound like a sawtooth wave.
Clean vocals will start to sound like Joe Cocker, etc.
If the woofers or tweeters hit Xlim, they may make clacking, or popping noises.
The voice coils will have heated up, which causes their impedance to rise, and the speakers will now not be as loud, thermal compression has set in.
Compression sounds different than uncompressed, less dynamic. A three dB increase in drive level may only result in a one dB increase in SPL.
As the voice coils change impedance from heating, the passive crossover points and slopes will change.
This sounds different, like an EQ change, usually a “thinner”, “harsher” sound will result.
Get yourself some cheap disposable speaker from Goodwill or laying unused in some closet.
Put your amp in bridge mono mode, play music through the speaker and listen.
Continue to turn the level up a dB at a time every 3 minutes. Use earplugs so your ears don’t distort, and listen for the effects listed above. If you hear clacking noises, raise the high pass filter.
I have moderately clipped a 400 watt amp into eight 4” speakers rated 5 watts RMS apiece, 40 watts RMS total, with no problem. The musical peaks were 10 times the speaker RMS level. Same ratio as 5000 watts into a 500 watt RMS speaker.
I have also (by accident) burned up a 100 watt RMS speaker in approximately one second with a 400 watt 200 HZ sine wave. If I would have turned that speaker up slowly, (and had not been doing tests while drunk) I would have noticed the distortion well before I had exceeded the power level by six dB.
I was reading a dB meter set on “A” instead of “C”, so it read about 6 dB SPL low, using my eyes instead of my ears...
You will probably be quite surprised how much peak power a speaker will take before it finally burns up if the music has reasonable dynamics.
Art Welter
