Tom,
Thanks for the input. I bought the 1804s specifically on advice from someone at bag end - they recommended not overshooting the rated power handling of the drivers by too much - on the spec sheets it says that the continuous sine wave and instantaneous peak are the same - 800 watts. I believe this has to do with it being a sealed chamber? They said an amp that would deliver 900 watts to each dual 18 cab (450 per driver) would work well, particularly given that most of the stuff i do is highly compressed, bass heavy electronic music. And while I do think that the bag ends sound very nice at low volume, as soon as you start pushing them you end up with a lot of distortion. And even if I could get a bit more output with larger amps, I just don't think the bag ends have the efficiency, or output to size ratio that I need. I'm sure I could get a bag end system to rock pretty hard given enough cabinets, but I don't really want to have to lug 10 or 12 dual-18 cabs to every show
speaking of amp power...
I'm wondering about how I should be planning amp power for new subs. I've done a good bit of reading, many threads, about appropriate power matching between amps and speakers, but in most cases these refer to live sound applications. Most of the shows I do will be DJ/Laptop live electronic, where the material is very (over)compressed, and is almost always going to have a good bit of (compressed) sine wave sub-bass in the 30-50 Hz range. So I'm pretty confident that the normal "rules of thumb" are not going to apply... My thoughts are currently to split the difference between the continuous and program, and make sure I never see the clip lights. For example, with 4 TH-212s, use two crown xti6000 amps, one sub per amp channel, and so be able to provide 2100 watts to each 4 ohm TH-212. Does this sound good, or would that still run a significant risk of blowing things up (give the nature of the program material)?
and what the hell, while i'm at it: Are there significant drawbacks to using amps in 4-ohm bridge mono mode / 2 ohm stereo mode? I ask because looking at price to output, if the goal is to power 4 TH-212s with around 2000 watts each, getting 4 XTi2000s, at around $600 each, one amp bridge mono 4-ohms per sub, versus two XTi6000s, at around $2k each, one sub per amp channel stereo 4-ohm... it doesn't seem that the extra 100 watts per sub would be worth the $1,600 price difference... but I'm sure there are factors I am ignorant of.
(btw, I'm not set on using XTi amps, they just have good numbers for my examples, I welcome amp recommendations and suggestions.)
also, ignore my previous post, got a call from Joel at Danley today, they are helping me figure things out with finding a dealer
