Author Topic: Question on Sabine Nav unit  (Read 801 times)
Jerome Casinger
    • http://www.ignitestlouis.com
« on: March 16, 2009, 09:32:53 pm »
Sabine Nav4800, Stereo and Aux Subs, One input free.
When would you use input eq's and compression as compared to output eq's and compression?
Just not sure why it is offered twice in the DSP or when would be an appropriate time for it.
Ive got it set up using eq on outputs and compression on outputs, right now everything is zeroed but thats where I plan to go for adjustments, is this wrong?
I also see there is Delays on Inputs and outputs, I could see Delay on inputs to fix alignment for the incoming sources I assume.
Thanks  Very Happy
Duncan McLennan
Re: Question on Sabine Nav unit
« Reply #1 on: March 16, 2009, 09:51:59 pm »
Input compression would compress the whole mix, output compressors you would more likely set as limiters for individual pass bands.
Same goes for delay.  Input delay would be for aligning to backline, etc., where output delay would be used to align subs to tops, etc.
dcm
Waterloo & London, Ontario
Jerome Casinger
« Reply #2 on: March 16, 2009, 09:54:07 pm »
Duncan McLennan wrote on Mon, 16 March 2009 20:51
Thank you for the clarification, having a great time learning the unit!
