k here goes! btw, this is an unofficial very brief time sensitive review of what i thought about the board when i ran the demo session it came with through the capture software.
i got my studiolive today around 5, opened it, and plugged it in. wala everything works. input gains are not detented. smooth, and easy to turn.
i loaded the software easy. i loaded the session easy.
im now mixing 16 dry tracks through the studiolive and im toying with the dynamics and levels of everything.
what i noticed is everything is real easy to get to. because there's no layering, accessing and knowing what part of the channel you are on is easy.
what i also noticed is the input levels, the output levels, the subgroup levels, and the master outs are not the same even though they are all as closely set to unity unclipped 0 level.
i know i had a topic a while back saying i had a problem with my gl2200 with the same problem. and yes, ive since corrected my gain structure and ive increased my headroom. since then, every board ive worked on ive had clean ins and outs and the gigs were less intense. it was user fault. my fault. and thanks for your help.
but with this board, the ins/outs/groups/master dont seem to be showing the same levels. my input gain on any given channel shows -6, but when subgrouped, it shows +10, the master out shows +3. thats what ive noticed. all while the fader, subgroup, and master out is at unity level. i dont like it. does the 01v96 do this.
what about other digital boards? im still gona get a ls9-32 in the future. i want one so bad. but im working on getting my yorkies first.
thanks,
j
